Block heater cord issues "HELP"
Old Nov 2, 2008 | 03:44 PM
diablo1's Avatar
I plugged my truck in for 1hour today to make sure everything was working properly for the season and when I went to unplug it I burnt my fingers on the plug. This can't be normal. This has never happened before. What do you guys think is going on before I burn my truck or house down?
Thanks for the help.
Old Nov 2, 2008 | 04:40 PM
CTD Hauler's Avatar
Too small or too long of an extension cord, also could be dirty/corroded plug connection.
Old Nov 2, 2008 | 04:47 PM
NickBeek's Avatar
Both issues will create heat.
My camper shore power plug got hot enough to melt the plastic around it. I now clean the prongs before each use.
Old Nov 2, 2008 | 05:33 PM
Jeff in TD's Avatar
You could also take an ohm meter reading across the prongs, just to be sure.
Old Nov 3, 2008 | 09:16 AM
davidj54's Avatar
Was the engine warm?
Most common cause of hot plugs is blade corrosion. Clean them good with a fine emery board and spread them a bit. Some dielectric grease won't hurt anything either. It'll help keep the corrosion down in the future. I'd also clean the receptacle of the extension cord too.
Old Nov 3, 2008 | 07:09 PM
diablo1's Avatar
The engine was warm not hot. I will clean the plug and get a heavier cord.
How would you clean the female part of the cord?
Thanks
Old Nov 4, 2008 | 08:22 AM
davidj54's Avatar
Trim an emery board down to fit in the slot then just stroke it in and out a few times. Be careful not to break it off in there. They're a bear to dig out!
Old Nov 4, 2008 | 03:05 PM
shep1's Avatar
I'd make sure the other end of the cord was un pluged!
Just a thought.
Old Nov 6, 2008 | 04:58 PM
phatboy's Avatar
Dipping it in CLR will clean it up real nice....also as mentioned above...make sure both ends are unpluged
Old Nov 6, 2008 | 07:03 PM
diablo1's Avatar
Thanks for the help. It all works.
rjm022
Dec 11, 2019 09:17 PM
aage
Sep 2, 2010 06:04 PM
Hummin Cummins
33
Dec 28, 2004 01:11 PM
truckjunkie
Nov 24, 2004 02:41 PM
mitchkim
36
Oct 28, 2003 04:18 PM
