Black Smoke rough idle Mystery
Old May 3, 2012 | 10:13 PM
Spencer Denton's Avatar
Ok I have been having this prob for a while. I put new injectors in bc I had some out, then when I got done and ever sense then it is idling rough and as I rev it up it goes smooth then rough an back an forth. It black smokes a ton when accelerating, slightly smokes when running about 70 mph, no smoke at idle. It gets bad mpg, about 11. Someone in an earlier thread thought I might have not got the injectors seated right so I tore them out an did them all exact to spec. Nothing changed it still does all the previous mentioned problems. I don't know what to do, does anyone think it could have anything to do with the ECM?
Old May 4, 2012 | 04:16 AM
DodgeRam24V's Avatar
did you get all 6 copper seats off the old injectors? one is not doubled up now is it?
Old May 4, 2012 | 08:11 AM
Yes I triple checked every cylinder
Old May 4, 2012 | 05:22 PM
that's a tough one, these 3rd gens are so hard on injectors, maybe one is still bad?
Old May 4, 2012 | 06:15 PM
Ya wuts the easiest way to check
Old May 4, 2012 | 07:22 PM
TxDiesel007's Avatar
hate to say it
but sounds like an injector is stuck open
Old May 4, 2012 | 08:50 PM
Ya could b r there any other things I should do b for I start replacing them again
Old May 5, 2012 | 07:45 AM
are they all new?
if it was my truck i would pull all 6 and have them tested at Diesel Injection Service in Grand Rapids Michigan.
find a authorized Bosch dealer in your area.
Old May 5, 2012 | 01:00 PM
Yes they are ok I think there's one in fort worth any clue how much that will cost??
Old May 6, 2012 | 07:31 AM
Diesel Injection Service charges $30 each, they said it is a lengthy process to check them out thoroughly
they do not knock the $30 off the new ones if you buy the new ones there either.
smoknblack01
Jan 12, 2013 07:40 AM
ienjoydrifting
Jul 4, 2010 11:37 PM
nate_88
Dec 18, 2008 11:06 PM
bloodywolf
Apr 5, 2007 08:29 PM
big red psd cc
14
Sep 1, 2004 01:39 PM
