Black Smoke. A lot of it.
Old Jan 17, 2013 | 07:45 PM
Big Boys Toy's Avatar
Hey guys my uncle has a white 2500 Cummins that he bought used with 25,000 miles. Every since he has had it when you take off from a stop it will just roll the coal almost to the point of being ridiculous.But once you get rolling and get the engine revved up it will stop immediately. It acts like the motor is dumping more fuel in than the turbo can feed air to but has been to the dealer numerous times to confirm that it has no kind of chip or programmer on it. So I contacted the previous owner to see if it had injector work done to it but he insisted that it didnt. I just dont know what else could cause this.
Old Jan 18, 2013 | 08:29 AM
jhenson's Avatar
Possible waste gate problem.....stuck open maybe. Is it low on power anywhere in the rpm range?
Old Jan 18, 2013 | 08:44 AM
Not thay I can tell. The power is about the same as my 04. And to tell you the truth I have an 01 as a farm truck and that thing whips these newer trucks as far as throttle response. I alwaysvthought it was due to most everything being mechanical on the pre-common rails. How would you check the wastegate? They are internal arent they?
Old Jan 18, 2013 | 08:51 AM
jhenson's Avatar
Yes, they are internal. Turbo would have to be pulled in order to check it. I use to drive a junky ol' 6.5 Chebby diesel at an old job once and that thing was absolutely gutless.....would pour smoke from a dead stop but once you got up to speed it cleared right up. Wastegate was stuck wide open and wouldn't let it build any boost.....not that any amount of boost would have helped that turd anyhow!!!
Not sayin that's your problem but it does sound familiar.
Old Jan 18, 2013 | 09:25 AM
Ok man i may try when I get off to pull the turbo tonight depending on how big of a job it is and see if that will fix it. Wish they wouldve left the turbo where it was on the 12 valves and older 24's. Thanks for the suggestion.
Old Jan 18, 2013 | 10:13 AM
1-2-3's Avatar
Just a plain ole guy
What year is it? With only 25,00 miles it may still have a warranty on it.
Old Jan 18, 2013 | 10:51 AM
47Dodge's Avatar
You were lucky! I had a Chevy 6.2!
47
Old Jan 18, 2013 | 12:15 PM
I meant he bought it with that many miles. It now has 147k on it.
Old Jan 22, 2013 | 10:53 PM
DragonSlayer's Avatar
My '05 will smoke as well. I don't have a tuner, but wondering if one is in it... I'm going to take mine into the Dodge dealer and have it flashed, that way it should be stock. Mine has plenty of power and mileage, not sure if she's tuned or not.
07_Ram
Mar 19, 2012 02:23 PM
wardy70
Oct 13, 2009 10:15 PM
6cylinders
Nov 5, 2005 02:57 PM
dhe9
Nov 14, 2003 07:31 AM
