Bhaf
Old Jul 21, 2005 | 10:26 AM
bishgeo's Avatar
Bhaf
Can I put a BHAF in my 05.It look;s like there is a mass air sensor or something in the air tube coming out of the air box.Also what is the deal with removeing the baffels it the new style air tube.Any part numbers for filters ,filter covers,or any other parts needed would be greatly appreciated.Thanks
Old Jul 21, 2005 | 12:16 PM
nickleinonen's Avatar
it can be done... i have one on my 04 and the install should be nearly the same on your 05... it isn't a mass air sensor. dodge calls it a map sensor [] i call it an intake air temp sensor. it also has a baro sensor [that's why 4 wires] you can leave it plugged into the harness but not in the air stream and it will work fine... i had mine like that until i put it back in the air stream.. no difference in feel/performance with it being in/out of the air stream
Old Jul 21, 2005 | 03:53 PM
Nuttymopar's Avatar
I just happened to have a 5" chromed stack around the house that replaced my Air Torque Tube. (check pictures). It added more sound from the turbo but I don't think it added more HP, maybe it did but it would be very small. Mostly for soundness and it was free.
Old Jul 21, 2005 | 04:22 PM
Flame's Avatar
BHAF Part Numbers
Hope this helps!
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
John Deere PMAH19037
Big A 93790
Caterpillar 3i0005
Fleetrite AHR819037
Luber-finer LAF2531
Fram CA6818
UNI 908
Cummins 3912986
Outerwear Cover WR3325-105
Heres one link to a source...
http://shop.airflowonline.com/Mercha...egory_Code=DCI
Good Luck!
Old Jul 22, 2005 | 04:12 AM
Dodgezilla's Avatar
My custom intake parts came from airflowonline.com......
Feb 22, 2024 07:16 AM
Rickcher
Sep 2, 2009 05:08 PM
Marine
113
Nov 6, 2007 06:24 PM
Ace
Oct 31, 2007 06:46 PM
