Bhaf
Old Aug 22, 2007 | 10:45 AM
thumbs's Avatar
The napa link with the filters. Boy these filters ain't cheap. Th Duralite air cleaner seems to be reasonable. I don't know how it filters.
Locally they want about 75 bucks for the Napa an Wix filters.
Old Aug 22, 2007 | 12:34 PM
tslewisz's Avatar
They're hosin' ya. I just bought a Wix locally for $40.
Old Aug 22, 2007 | 01:36 PM
thumbs's Avatar
Yep Napa was 74 bucks and Wix was 73. I gotta be able to do better than that.
I really can't get goin on this thing until I get a filter or...by any did you not install your filter yet? If not could you send the measurments so I can start lookin of a container for this thing?
thanks
Old Aug 22, 2007 | 03:18 PM
tslewisz's Avatar
Mine's installed, but the Wix site shows the specs as:
Part Number: 42790
UPC Number: 765809427907
Principal Application: Donaldson Disposable Housing
All Applications
Style: Air Filter
Service: Air
Height: 11.880
Outer Diameter: 10.500
Inner Diameter Top: Closed
Inner Diameter Bottom: 4.000
Ends: Plastic
CFM: 680
Old Aug 22, 2007 | 05:00 PM
thumbs's Avatar
Ok thanks. I measured the opening on the intake hose that goes from the filter to the compressor. It's a 4.5 in ID. I guess that is the reason everyone goes with the new pipeing and elbows from the filter to the compressor. I was hopeing I could use the original pipe.
Sorry but I forgot. Are you using the ol smokey mount? I make a template this afternoon and it seems like it enclosed the filter pretty well. The end toward the windshield res can be filled and the lower part of the mount toward the radiator can be filled also. That would pretty much draw in cold through the front where the original "scoop" was and around the lights and such.
What are your thoughts about the ol smokey mount? Do what I am saying make sense?
Old Aug 22, 2007 | 05:31 PM
tslewisz's Avatar
I'm not using any mount - it just lays in there! Can you shoot me a link to this "ol smokey mount"? Is it strictly a 1st gen thing?
Old Aug 22, 2007 | 05:44 PM
thumbs's Avatar
BHAF mount:
https://www.dieseltruckresource.com/p...rt=1 &cat=500
https://www.dieseltruckresource.com/p...rt= 1&cat=522
I dono. See if you can use it. Mine fits on the right fender just in back of the headlight. The second site is a better drawing.
Old Oct 25, 2007 | 12:10 PM
jbworm20's Avatar
Originally Posted by tslewisz
You replace the air box with the BHAF and relocate the air sensor and filter minder. I didn't reuse the filter minder since the new filter is so danged big I didn't think it was necessary. You end up with something that looks like:
where do you relocate the air sensor to?
Old Oct 25, 2007 | 02:41 PM
RDyson's Avatar
You can buy the BHAF filter from Fleetfilter.com. It is a Napa filter for about $35--as of a year ago.
Randy
Old Oct 25, 2007 | 05:35 PM
VFDFireman's Avatar
I did a very similar mod to the '00 PSD that I used to have. On those trucks, the sensor was just used to measure the incoming air temps. Most people just zip tied the sensor to something near the filter.
Any reason that this couldn't be done on a CTD?
Old Oct 25, 2007 | 08:43 PM
tslewisz's Avatar
I drilled a hole in the flex tube "thick part" for the sensor and reused the screws if I remember correctly.
Feb 22, 2024 07:16 AM
Rickcher
Sep 2, 2009 05:08 PM
Marine
113
Nov 6, 2007 06:24 PM
Ace
Oct 31, 2007 06:46 PM
