Bhaf
Old Oct 31, 2006 | 08:42 PM
pullin hard's Avatar
Bhaf
looking for a part number for the BHAF for like an 03 truck, and i am also looking for the part number and a place i can order a pre filter.
don't care who makes it , or what colour it come in, just can't seem to find what will fit the air filter.
Old Oct 31, 2006 | 08:55 PM
new2ctd's Avatar
pre-filter
http://www.outerwearsracing.com/prod...DCFABA45352E9D
http://tinyurl.com/wm3pu
BHAF part numbers
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
John Deere pmah19037
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
Old Oct 31, 2006 | 09:01 PM
Danderson's Avatar
Drc
DRC sells the whole thing including tube,outerwears,etc. Pretty pricey.www.desertracingconcepts.net.
Old Nov 1, 2006 | 08:42 PM
thanks for all the info!!!
Old Nov 1, 2006 | 09:03 PM
BlueDually's Avatar
Fleetguard ah19037 + a 4" exhaust 90 + outerwears
Old Aug 13, 2007 | 12:04 PM
mstordahl's Avatar
Will this Fleetguard part number work for a 2006 Cummins 5.9? Do you know the correct part number for a 2006 5.9?
Old Aug 14, 2007 | 01:24 AM
motrapper's Avatar
you are joking right because this is not a factory replacement this is a modification just like adding a AFE stage 1 or 2 not a stock replacement and
it will work on a 89 to a 07
Old Aug 14, 2007 | 09:44 AM
tslewisz's Avatar
You replace the air box with the BHAF and relocate the air sensor and filter minder. I didn't reuse the filter minder since the new filter is so danged big I didn't think it was necessary. You end up with something that looks like:
Old Aug 19, 2007 | 05:00 PM
tslewisz's Avatar
Oh, you guys shamed me into an Outerwears, BTW.
Old Aug 21, 2007 | 08:09 PM
thumbs's Avatar
Ok I need a BHAF for my 92. I gotta hear that stage III I just put in. I am running a stock AF now.
I want the BHAF to really work and clean the air. I don't wnat a "low restriction" or something that will let particals through. That being said which one do you guys suggest and can I get a prefilter for it. Also with this filter work with my stock intake hose?
thanks for the help
Old Aug 21, 2007 | 09:00 PM
motrapper's Avatar
ok guys dont want to hi jack the thread but i have a bd cool hose and since it can hook straight to the factory air box and i have seen how the guy above attached the bhaf to it when i tried to hook the bhaf to the cool hose it would not fit please tell me what iam missing
thanks guys
Old Aug 22, 2007 | 08:41 AM
tslewisz's Avatar
Hey, thumbs, you might want to ask that question in the 1st gen area. I don't know what diameter inlet you might need. You can probably figure out the filter you need if measure the diameter of the hose you want to attach to it, then crawl through this list to figure out what filter you need:
http://www.fleetfilter.com/Store_Vie...cts.asp?Cat=53
Click on the part numbers for dimensions. Outerwears will make you a pre-filter in any size.
motrapper, all I can tell you is that the stock hose was a bear to put on the BHAF the first time. Really had to stretch it.
Old Aug 22, 2007 | 08:43 AM
thumbs's Avatar
Yep probably right thanks
Old Aug 22, 2007 | 09:00 AM
thumbs's Avatar
tslewisz
thanks got it. I found a list of filters somewhere with part numbers. I just have to find it again.
Old Aug 22, 2007 | 09:51 AM
tslewisz's Avatar
You mean like the link in my post?
