Before I drain the diff...
Old May 26, 2007 | 03:02 PM
svanni's Avatar
...can somebody tell me if there's a specific gasket, or is it RTV ?
It's an '06 with 16k miles, half of that is hard towing.
Thanks in advance.
Old May 26, 2007 | 03:03 PM
$oC@l CTD's Avatar
Thanks in advance.
The one on it is reusable...just clean it off, rub a little oil on it and reuse it
Old May 26, 2007 | 03:27 PM
Rollin' Smoke's Avatar
just dont tear it up prying the cover off.....
Old May 26, 2007 | 03:34 PM
$oC@l CTD's Avatar
See, when I did mine, I took out all the top half bolts and just loosened the bottom half until all the fluid started draining out...then I took them out the rest of the way from the top to the bottom and my differentials just fell off...I didn't have to pry or anything.
Old May 26, 2007 | 03:41 PM
Luvnacumns's Avatar
X2!!! Mine did the same thing!!
Shane
Old May 26, 2007 | 04:23 PM
Pooter's Avatar
Shane
Same here...
Loosened them all up, took all but two bolts on the top off and it popped off(both of them)
Only problem I had was filling the front back up, but I just stuck some 3/8" hose over the end of the nipple on the bottle and filled it up. Kind of a bad angle to squeeze the bottle in between the steering tie rod/diff
Old May 26, 2007 | 05:54 PM
Mike_Boutet's Avatar
When ever i take off a diff cover, i do just the opposite. I start at the bottom and leave one loose at the top. That way i'm not getting my hands full of fluid when removing the remaining bottom bolts. Everybody has their own way of doing things that suit them. That's just mine. Not saying it's any better, that's just what i do.
Old May 30, 2007 | 05:29 PM
well i did the same thing as you guys but I had to use a little presure to get the cover loosened up to let it drain before I removed the rest of the bolts
desertchecker
14
Feb 18, 2008 09:32 AM
klx650a2
Jan 10, 2008 12:08 AM
DodgerDoob
Dec 27, 2006 06:41 PM
rjweiss
87
May 27, 2004 04:56 PM
wooff
May 1, 2003 11:22 AM
