baldwin fliters
Old Mar 20, 2005 | 09:35 PM
hooked3800's Avatar
baldwin fliters
anyone know if baldwin oiland fuel filters can be used on a 04.5 600 without voiding the warranty? thanks in advance
Old Mar 21, 2005 | 12:25 AM
Nevada's Avatar
You are thinking of an old mid-second-gen era TSB that came after some trouble with Fram filters, if my foggy old brain recollects correctly there was also a similar first-gen era TSB after some problems with Wix.
First of all, D-C cannot force you to use a specific filter without providing it at no charge. Second, they cannot refuse warranty services unless they can prove that the specific filter you used is responsible for the problem. Unfortunatey, these cases have a reputation of turning into you proving that you are innocent rather than the manufacturer proving that you are guilty.
The real answer to your question is that most people on this board find comfort in using Fleetguard filters since they are a Cummins product, reasonably priced and easy to find.
Baldwin has a very good reputation in the trucking industry. I would not have a problem using one on my truck.
Although I choose to use Fleetguard, I seem to remember that Fram and Wix redesigned their products as a result of the findings that led to the TSB's.
I do not work for or represent any of the companies noted. These are my opinions based largely on what I have learned from this site.
Old Mar 21, 2005 | 08:00 AM
Buckshotmckee's Avatar
Re: baldwin fliters
Baldwin is all I run. My bro has an 04.5, 600, and thats all he runs also.
Old Mar 21, 2005 | 09:23 AM
jwtuc's Avatar
I use Baldwin fuel and Wix oil filters.... no problems .
Old Mar 24, 2005 | 04:08 PM
mini14's Avatar
ive read that u cannot get a better filter then a fleetgaurd stratopore.
Thats all ive been using for past 5 years. another good choice would be the donaldson extended life line of filters.Donaldsons is oem on most big trucks, and has a great reputation.
PeytonMaterne
Jan 29, 2006 10:31 AM
jj3500
Apr 3, 2005 12:14 AM
MARKY MARK
Jan 23, 2005 04:14 PM
MonroeDiesel
Jun 27, 2003 03:59 PM
