bad lift pump?
Old Feb 14, 2009 | 03:07 PM
monsteredge's Avatar
bad lift pump?
I was driving home from work yesterday and went to pass a car when i stepped on it the engine started surging really bad like it was running out of fuel. I got home and turned the smarty back to stok its alot better now but if im crusing down the highway i cant get anything over 2100 rpm. I just replaced the fuel filter about 4000 miles ago so im guessing thats not it but im going to drop a new one in it today just to see. truck has 102,000 miles on it and as far as i know it still the original lift pump. im guessing its the lift pump, any other ideas would be great before i spend the money on a new pump
thanks
Matt
Old Feb 14, 2009 | 03:14 PM
sallyman1's Avatar
dont know. do u have a lift pump gauge?whats ur rail and lift pump pressures?
Old Feb 14, 2009 | 03:26 PM
the only gauges i have are boost egt and trans temp. i dont have anything to moniter fuel pressure at the pump or the rail
Old Feb 14, 2009 | 03:29 PM
sallyman1's Avatar
could be faulty fca regulator
Old Feb 14, 2009 | 07:30 PM
mj1044's Avatar
were is the fca regulator located at? any way to tell if it is bad?
Old Feb 15, 2009 | 09:48 AM
i tried a new filter in it this morning and before i tried starting it i turned the key a few times and rolled the engine over to fill the canister. when i started it, it ran for a few seconds then shut off like it ran out of fuel. i did notice when i first turnede the key i could not hear the pump running like i used to, insterad it was just a clicking sound. after this im guessing its the pump. thinking about putting an air dog on it should i go with the 100 or 150 and how hard are they to put in?
Old Feb 15, 2009 | 11:30 AM
Spooler's Avatar
Go with the Airdog 100. Plenty of fuel and easy to install. No need to install a draw straw.
Old Feb 15, 2009 | 01:04 PM
vj_M's Avatar
depends if its not got the update.......
Old Feb 15, 2009 | 08:39 PM
yepuhuh's Avatar
Where does everyone install these airdog's?
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
loveturbowine
Jul 26, 2005 05:50 PM
Txwelder
May 19, 2005 06:10 PM
C Pierce
Mar 21, 2005 08:41 AM
