auto tranny question
Old Feb 6, 2009 | 10:24 PM
RTA Cattle's Avatar
I have 2 questions/problems.First,my truck wont shift at WOT, Ihave to back off of the throttle so it will shift, otherwise it just hangs at red line.It is really frustrating when trying to pass someone.Second, There is no difference when in tow/haul mode.I can push the button at say 55, truck will downshift/unlock converter for a few seconds and then right back to normal.I thought it was supposed to keep the revs up to help towing in the hills. Any Ideas? 147000 no mods.
Old Feb 7, 2009 | 08:50 PM
RTA Cattle's Avatar
bump to the top
Old Feb 7, 2009 | 09:46 PM
no_6_oh_no's Avatar
The no shift at WOT throttle is probably the goernor solenoid/transducer problem that is prevalent on these transmissions. You can replace with the factory pieces or try an performance mod from PATC.
Tow Haul on an 05 is a shift modification program. It no longer locks out OD and keeps the rpm's high. What it does is lock the TC sooner and firmer and hold the gears longer under loaded acceleration. The down side is it tends to shift back and forth a lot at speeds under 60 mph when loaded.
Old Feb 7, 2009 | 11:21 PM
RTA Cattle's Avatar
Thanks, I will look into that.
Old Feb 8, 2009 | 10:05 AM
dozer12216's Avatar
On first issue: I would think a check of throttle pressure would be first to inspect. Tranny throttle lever must be fully forward with no slack or preload at closed throttle.
Old Feb 11, 2009 | 07:58 PM
ballewCTD04's Avatar
my 2004 did the same exact thing, it shifts fine on light throttle but if u mat it to the floor its like it's in neutral and red lines until you let off. well dont worry your problem is going to be fixed for about $130.00 all you need is a government pressure solenoid, and a gov. pressure sensor. one of those two is your problem but just buy them both to be safe, takes about 20 mins tops to install on your valve body. if your truck is like mine it will run fine after those replacments.
Old Feb 11, 2009 | 08:38 PM
RTA Cattle's Avatar
Thanks for the info, where is the best place to order these?
Old Feb 11, 2009 | 09:36 PM
aborgardt's Avatar
The dealer. I just replaced mine for the same problem and the parts guy told me that they always change the transducer and the solenoid at the same time. He said they run hand in hand. Made sense to me. If i remember right one was 125 and the other around 75. Might as well do it while you have the pan off.
Old Feb 12, 2009 | 06:28 PM
no_6_oh_no's Avatar
He has an 05, no more adjusty like the older ones.
Only if you want o over pay like 200% for the SAME part. Here is a better price than the dealer. Sensor is on the same page, about $50 a piece.
http://www.transmissionpartsusa.com/...-000053396.htm
Old Feb 12, 2009 | 11:02 PM
RTA Cattle's Avatar
Thanks for the link, no 6. The parts have been ordered, I hope this solves my problem. Thanks to everyone for your input
Old Mar 9, 2009 | 08:47 PM
RTA Cattle's Avatar
update
Well I finally got around to putting in the parts today and wow its like a different truck. It will actually pull through all the gears now. I know I should have done this sooner but its right in the middle of calving season so free time is hard to come by right now. Thanks for the help.
Old Mar 9, 2009 | 08:54 PM
no_6_oh_no's Avatar
Glad it was a simple fix and it worked.
Diesel4blood
Jul 21, 2014 04:23 PM
zethtays
Nov 3, 2010 06:24 PM
lews930
Mar 7, 2007 06:33 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
