Attn All 1 Owner Dodge Diesel Truck Owners
Old Nov 26, 2012 | 12:33 PM
  #31
ssandlin's Avatar
Truck in sig bought new in Feb 2006. Original CP3 and injectors with 133K miles on the clock. I change the fuel filter every 10K miles.
Old Nov 26, 2012 | 12:48 PM
  #32
mattk50's Avatar
Bought truck new May '04
Year---------------2004.5
Origional inj.pump---yes
Origional injectors---yes
Miles on truck-------239,000
Old Nov 26, 2012 | 03:27 PM
  #33
steelblitzkrieg's Avatar
DTR Detective
Purchased new, 83K presently.
2 injectors at 42-45k, 500 miles apart. I think they replaced the wrong injector and that's why 500 miles later I had "another one" fail.
Old Nov 26, 2012 | 08:38 PM
  #34
grapplerusa's Avatar
180,000
Original IP, all original injectors, replaced lift pump at 90,000. 180,000 miles mostly light towing. Have used B2-B5 fuel for 90% of fill ups and 5 micron Baldwin or Hastings fuel filter.
Old Nov 26, 2012 | 09:08 PM
  #35
dogcamo's Avatar
2005
Orginial IP
Orginial injectors
60k on the clock
Old Nov 26, 2012 | 10:57 PM
  #36
JessePHX's Avatar
2007 mega can bought new 70k miles in the middle of replacing injector.
Old Nov 27, 2012 | 04:17 AM
  #37
6spd05Dually's Avatar
Originally Posted by Grit Dog
I wouldn't say it's alot of people that have low mile problems. Only a couple here out of the 30 or so responded.
Mine:
'07 5.9
May as well of bought it new, only 10k mi on it when I purchased. 105k now.
Orig CP3 and injectors. WIX gold fuel filter with every oil change.
Have often thought about add'l filtration, maybe a aftermarket lift pump, but seems there's enough trucks like your with a crap load of miles on an orig fuel system to not warrant it for me.
Why do you say someone is trying to sell you new sticks or pump if the truck runs fine as is.
Happy with mine so far. Knock on wood, not many of the "common" problems....yet. Orig front end components, ujoints, 2 piece rear d shaft that is still fine. Only lost a #4 inj line, 1 steering box and it seems to like to eat power steering pumps (rebuilds) but I can't handle shelling out the $800 the dlr wants for the "new, better" PS pump setup.
Grit, I never said alot. I said "some" people. To answer your question, the people I have told my current mileage to who sell injectors etc. tell me it's time for some new ones. That's why!
Old Nov 27, 2012 | 08:35 AM
  #38
truckjunkie's Avatar
- 136000 miles
- replaced IP @ about 60K - it didn't fail, just had that slight seepage of fuel some of them get. Got it replaced under warranty.
- original injectors
- replaced water pump @ about 70K - warranty
- replaced ball joints @ 125K
- replaced one axle u joint @ 135K
Old Nov 27, 2012 | 11:46 AM
  #39
chrism69's Avatar
06 2500, original pump and injectors. purchased new now has 102,000.
Old Nov 27, 2012 | 01:08 PM
  #40
NJMurvin's Avatar
Original pump and injectors. Lost the water pump at around 60K. Dealer replaced out of warranty at my cost. It was so close (just over 7 years), I appealed to Chrysler and they covered it.
Old Nov 27, 2012 | 08:22 PM
  #41
bradler's Avatar
2005 model year Bought new in August of 2005
98,000 miles
2mic filter since 30,000 miles
New CP3 at 60,000 because incompetent dealer was shotgunning parts at an injector problem
1 injector at 45,000 replaced with a reman under warranty
reman failed again at 60,000
lost another injector at 75,000 sent them all to F-1 for a rebuild.
Other than ball joints twice, two steering gears, a fan clutch, water pump, alternator, an AC that has never worked, and an exhaust that rusted out and fell off truck works ok sometimes
Old Nov 27, 2012 | 11:26 PM
  #42
gadget.35-06's Avatar
227K on truck in sig. One A/C compressor, two clutches. Latest is a dual-disc. Noisy, but it hooks up. It's a truck. Not a Lamborghini.
Old Nov 28, 2012 | 03:22 AM
  #43
trik396's Avatar
Stock cp3 never touched.
Stock injectors never touched.
106,000 miles currently.
2005 2500 4x4
Old Nov 28, 2012 | 08:47 AM
  #44
MRoman's Avatar
Bought new in 2006.
159,000 miles
Original Injectors
Original Pumps (cp3 & Lift Pump)
I used a PS & MMO Mix in every tank for the first 2 years, then installed a GDP 2 Mic kit at 38,000.
Old Nov 28, 2012 | 06:04 PM
  #45
85glht's Avatar
Originally Posted by 6spd05Dually
Year?
Original injection pump or replaced?
Original injectors or replaced?
Miles on truck now?
2005
Injector pump replace @ 42k
Original injectors
49k
