Attn All 1 Owner Dodge Diesel Truck Owners
#49
2006, 53,238 miles.... all original components. Nozzle tips fixin to get replaced with these DDP 50 hp. tips that have been sitting in my shop for several years...
Stock filtration that is fixing to get upgraded with the Cat filter kit..
#50
All Original
235,000
Only, things I've had repaired was Idler Pulley, Water Pump and #4 Injector line. I change my oil between 10,000 and 15,000 miles and I think I remember changing my fuel filter at 200,000.
All Original
235,000
#52
96 2500 4x4 - just bought from original owner
Orig pump
Orig injectors
86k miles
91 w250 - bought from the 2nd owner that owned it since 1995
Original pump
Original injectors
280k miles
Orig pump
Orig injectors
86k miles
Original pump
Original injectors
280k miles
#55
Aint much help with just turning 70k yesterday on my 04. Only thing I had done under warranty was a leaking rear pinion seal. But, I also changed ball joints and performed the upgraded steering linkage along with a box stabilizer @ 69k. And really, the only reason i did the front was because I was bored....and i am glad I was bored. Drives better than new!!
Pump and injectors seem to be doing just fine..
#56
2005 bought march 2005 new.
125k on original lift pump, injection pump and injectors. Regular maintenance and only power train mod is a super chips flashpaq on economy setting. Run winter fuel most of the year. Regularly see below 0 temps.
#57
2005
90k miles (mostly highway)
original injector pump
original injectors
Aside from replacing the water pump and rear drive shaft u-joints, I haven't had to replace anything else. I've been running 35" tires on stock wheels since I bought the truck.
Very happy with the truck!
#58
Year 2006
117K miles - mostly freeway w/no load.
Have Smarty Jr but drive very conservative.
Original everything; except tires and one set of ball joints (with the front end steering upgrade done at same time), and regular fluid changes (Red-Line synthetic oils).
#59
Factory injector pump and injectors. Bought the truck new, now has 106000 miles. I have replaced tires, ball joints, U-joints, brakes, not much else. I change the oil every 15000 miles, fuel filter every other oil change.
#60
Bought off lot in Aug '05 (May build date). 142K mi so far.
Front and rear pinion seals under warrenty.
Driver side u-joint 3x, last time at 125k mi.
Ball joints at 80K mi.
Front end upgrade at 110K mi.
Front brakes at 125K mi.
Dodge steering stablizer at 130K mi.
Rear u-joint at 135K mi.
Water pump, belt and thermostat at 140K mi.
Ready for my 3rd set of Michelin tires.
Synthetic oil every 5K mi. Fuel filter every 20K mi.
