Attn All 1 Owner Dodge Diesel Truck Owners
Old Nov 24, 2012 | 07:57 PM
woodperson's Avatar
07, 110000 miles, 1 injector replaced. Injector pump replaced (I gased it).
Old Nov 24, 2012 | 09:00 PM
banyon's Avatar
All 6 injectors replaced short of 100,000 miles, factory recall. Two replaced around 150,000 (?) One was bad, one was weak so I replaced it while I had it out.
Old Nov 24, 2012 | 10:25 PM
FMB's Avatar
FMB
'03
Original injector pump
lift pump swapped pre-failure @ 100k miles with aftermarket pump
#1 Stick replaced under warrantee at ~97,500 miles
6 rebuilt sticks at 215,000 miles
248,000 miles now
Old Nov 24, 2012 | 10:26 PM
rockcrawler304's Avatar
Year? 2006
Original injection pump or replaced? Original
Original injectors or replaced? Original
Miles on truck now? 115,000
About 85% of the miles are highway.
I sure could use a new clutch though!!
Old Nov 24, 2012 | 11:18 PM
Justwannabeme's Avatar
DTR Mom
i don't feel so bad. 172,544 miles, towing or hauling.
2004 order feb, delivered april. 3500 single rear short box. RR, off road 4x4 package. we abuse this truck in the hilly woods, over load it with steel, drive it up 60 degree banks at the marina and tow big boat 19,000lb frequently. that motor will still put you deep in the seats. 4 wheel low is no joke.
original everything. even air "flow" box, which isn't.
I did a custom rebuild on the tranny when the case leaked.
eighteen wheel bearings, ten u joints, 3 rotors, run flat , 10 ply 20 inch tires.
the box is whupped from bad loader operators.
dealer screwed up the nav system, we never got the sales pictured one anyways.....
Old Nov 24, 2012 | 11:52 PM
6spd05Dually's Avatar
I am amazed at the lack of miles some people get when an injector or pump goes out. What is not being done to keep the longevity up? I guess that is the 64 dollar question that will never be answered.
Old Nov 25, 2012 | 01:45 PM
FMB's Avatar
FMB
I'm guessing it is the vast differences in the quality of fuel across North America. It would be interesting to see test results from many CTDs, half of which having 2 micron fuel filters from the git go.
Old Nov 25, 2012 | 02:44 PM
banyon's Avatar
I forgot to put that mine is an 06, I did replace the lift pump but only because of bad advise from the dealer. I also added a second fuel filter when I replaced the two injectors. I think if I owned a dealership I would push the severe duty filter system to all diesel buyers. Maybe the newer trucks have a better filter than mine.
Old Nov 25, 2012 | 04:31 PM
Coolride17's Avatar
All original stock truck,103k so far . Original filtration too.
Old Nov 26, 2012 | 02:52 AM
FastTaco's Avatar
06
cp3 is original with a arson 3 kit
stock injectors
108k
Had water pump replaced this summer on mine too.
Old Nov 26, 2012 | 08:07 AM
TJAR66's Avatar
Year - 2006
Original injectors
Miles on truck now - 110,000
DD for a couple years. Lots of towing.
Old Nov 26, 2012 | 08:44 AM
FiverBob's Avatar
03 HO engine.
90,000 miles
No changes to anything except the water pump.
Bob
Old Nov 26, 2012 | 10:08 AM
alboy's Avatar
06 3500, 70000 MILES, all stock,75 % towing heavy.
Old Nov 26, 2012 | 10:45 AM
Grit Dog's Avatar
I wouldn't say it's alot of people that have low mile problems. Only a couple here out of the 30 or so responded.
Mine:
'07 5.9
May as well of bought it new, only 10k mi on it when I purchased. 105k now.
Orig CP3 and injectors. WIX gold fuel filter with every oil change.
Have often thought about add'l filtration, maybe a aftermarket lift pump, but seems there's enough trucks like your with a crap load of miles on an orig fuel system to not warrant it for me.
Why do you say someone is trying to sell you new sticks or pump if the truck runs fine as is.
Happy with mine so far. Knock on wood, not many of the "common" problems....yet. Orig front end components, ujoints, 2 piece rear d shaft that is still fine. Only lost a #4 inj line, 1 steering box and it seems to like to eat power steering pumps (rebuilds) but I can't handle shelling out the $800 the dlr wants for the "new, better" PS pump setup.
Old Nov 26, 2012 | 10:52 AM
RTillery's Avatar
Year? 04
Original injectors or replaced? Replaced at 220,000
Miles on truck now? 314,000
Still running great!
