Attn All 1 Owner Dodge Diesel Truck Owners
1998 Dodge Ram 2500 currently with 288,000 km (179,000 miles) Purchased November 1997 still has original injector pump and injectors. This 12-Valve engine and it's components are hard to beat.
2005 2500 quad cab 4x4 with 164k miles
5k position crank sensor replaced under warranty.
38k air conditioning compressor
76k air conditioning compressor. Replaced with aftermarket. Still going strong
150k rear u joint
160k 4wd shift linkage fell out. Replaced with a new one
150k rear u joint
Year =2006
Original injection pump or replaced= Original
Original injectors or replaced= Original=173,000, current=175,000
Miles on truck now= 350,000
About 60% of the miles are highway.
2005 - 55k on the odometer
Cp3 pump replaced at 40xxx miles. I believe the pressure box I was running was the culprit that took it out. (Running a Smarty JR. now at 100 hp.)
Injectors are original.
Front end, replaced universal joint and all ball joints.
Replaced factory radio to have one with a back up camera installed.
Other than the front end, truck has been great.
Update.....
2005 2500 quad cab 4x4 with 169k miles
150k rear u joint
165k #4 injector line blew and sprayed diesel all under the hood. Replaced with a new one, easy fix
150k rear u joint
