Antifreeze
Old Mar 19, 2007 | 12:03 PM
TXDRAM's Avatar
Antifreeze
Hey guys, bit of a problem today. My water pump went out today and was needing to know how much DEX/antifreeze to use. I mean what is the capacity?
Old Mar 19, 2007 | 12:23 PM
Peterbilt's Avatar
I believe you should be using HOAT (I think Zerox makes it). Avoid DEX. I think around 4 gallons, but not sure. I need to do mine to. Do you have the owner's manual?
Pete
Old Mar 19, 2007 | 01:25 PM
JJ's CTD's Avatar
Total coolant capacity is 7gal. And use only Zerox G-05 (hoat) or the Mopar stuff. I know because I had to change out mine last week. I bought 3gals of antifreeze. After I took off the old pump, I drained the rad.. So with refilling the rad., block and reserve, I put about 5 1/2 gal of 50/50 mix back in. It should be good for the next 5yr/150k, that's what the bottle says.
JJ
Old Mar 19, 2007 | 02:04 PM
annabelle's Avatar
Hoat compatable .....Zerox
Old Mar 19, 2007 | 07:39 PM
TXDRAM's Avatar
Antifreeze
Thanks, I got the pump on with out much cussing. I was told dex was what I needed so that is what I have in it now. Is this going to be a problem? Thanks.
Old Mar 19, 2007 | 09:18 PM
WhoozYaDaddy's Avatar
Might be, MOPAR (GO-5) and Dex-Cool are incompatible according to Dodge. Dodge warns not to mix these 2 products. Dex is OAT, GO-5 is HOAT.
Old Mar 19, 2007 | 11:41 PM
annabelle's Avatar
I have been told dex is a no no. Go with HOAT rated.
Old Mar 23, 2007 | 12:21 PM
surfingcardiff's Avatar
Go with the Fleetguard, because it's much cheaper than the MOPAR. I just flushed my 2005, and I believe the capacity was about 6 gallons.
Try the Fleetguard ES Optimax - it's supposed to be good for 300,000 miles.
My Dodge dealer and Cummins both told me not to use the Dex-Cool.
Old Mar 23, 2007 | 12:29 PM
new2ctd's Avatar
The Zerex is HOAT and its clear as water.
http://www.valvoline.com/pages/produ...asp?product=10
I don't like it being clear because I'm sure a dealer will try to say you're running straight water.
Old Mar 24, 2007 | 02:35 AM
Vinceg99's Avatar
Tell em to drink some
dodgediesel
Sep 23, 2007 03:27 AM
rattle_rattle
Apr 30, 2005 09:09 AM
WDS41
Jun 27, 2003 12:31 PM
drecu
May 4, 2003 12:31 PM
Fillerupsonny
Oct 8, 2002 01:22 PM
