another trans go question
Old Apr 16, 2009 | 06:50 PM
1985cucv's Avatar
i was reading a post by someone and they said when you pull the valve body a spring and a ball will come shooting out? is this true? and if so where does it go, i will be doing mine this weekend or next thanks
Old Apr 16, 2009 | 08:54 PM
matt69olds's Avatar
When you remove the V/B the accumulator piston and spring may fall out, just reinstall it and use lots of Vasoline to kind of "glue" it in place. The vasoline disolves in the fliud when the trans warms up. When you disassemble the shifter linkage you may lose the detent ball and spring so be careful! When it comes time to reinstall the detent ball and spring use a zip strip to hold the ball in the compressed position. when everything is back together cut the zip strip off and your good to go! Good luck!
Old Apr 17, 2009 | 08:16 AM
lniemeyer2's Avatar
Its not to bad of a job I did mine last weekend. The only thing I wish I would have done different is leaving in the stock throttle vavle spring, there is a note in the instructions, to keep the shift points the same. I think it would be a great mod with the shift kit spring if I towed everyday but since it is my daily driver I don't like the way it holds off the shifts under light throttle.
Old Apr 19, 2009 | 10:18 AM
yellowhemi's Avatar
Mine is going to the local trans shop to be installed. I don't want to make any mistakes.
Old Apr 19, 2009 | 11:17 AM
xtoyz17's Avatar
I had intended on doing the same thing. I fubar'd a band adjustment and said screw it just do the shift kit, and adjust the bands. Come to find out, the whole trans was shot. Anyways,long story short is a full build later I have a pretty sweet transmission that puts the power down and shifts a million times better. Had my stock transmission been good to go, I think I would have been VERY happy with just a shift kit but this is even better.
Either way, I wouldn't hesitate to have someone "trained" do it for the right price. Or, just buy a valve body and put that in yourself.
Shawn
RGBruce3
Jul 31, 2008 05:51 AM
gscmiller
Aug 15, 2007 10:43 AM
Taucoin
Nov 2, 2006 08:01 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
NHDiesel
Oct 3, 2005 11:14 PM
