annother 48RE Question
Old Oct 8, 2005 | 11:51 AM
Larryb01's Avatar
I have an 05 auto and pull a 5th. was wondering if the idiot light on the dash is sufficient warning or should I install a guage? Does anyone know at what temp the warning light would go off ?
Old Oct 8, 2005 | 12:21 PM
odie2219's Avatar
260 degree's
Old Oct 8, 2005 | 12:31 PM
hardyhindle's Avatar
You also get some extra warning before that happens.. I'm not sure what temp it happens at, but the tranny will dump a gear to help cool itself off if it gets too hot. This happens before the light comes on. I've only ever had it happen once, on a good long uphill grade. It took a couple miles before it would shift up again.
Old Oct 9, 2005 | 11:36 AM
davelinde's Avatar
I've got a gauge and have hit 265 without lighting the idiot light.
I did it backing into a tight spot on a hot day with the trans at 220 when I got there. I'd suggest a gauge to give you some idea before the light comes on.
Old Oct 9, 2005 | 12:25 PM
Prodart440's Avatar
Where does the factory measure the temp. from??
Old Oct 9, 2005 | 04:10 PM
davelinde's Avatar
Not sure, but I tap the same sender with my X-monitor. It's possible that I'm not calibrated the same as the light... hard to say.
Old Oct 10, 2005 | 08:49 PM
tmcblane's Avatar
Is there an easy place to tap into the tranny? Maybe a port that is just plugged?
Old Oct 10, 2005 | 09:05 PM
runamuk's Avatar
I just ordered a trans pan and guages from MDW hotroddiesel.com. The pan including the extra fluid capacity is tapped for a temperature sensor. This is by far the easiest way to tell actual trans temp.
Rick
Old Oct 20, 2005 | 12:42 AM
Larryb01's Avatar
I had my x monitor from my 01 re-installed into my 05.I had BD install the trans. temp. in place of the fuel presssure on my 01 install. When I picked up my truck on the way home I noticed my tranny temps were at 135 to 140 degrees all highway no hills driving. I wonder how accurate that is? Ithink they tapped into existing sensor wiring.
Old Oct 20, 2005 | 05:34 PM
davelinde's Avatar
I'm betting I'm on the right wire since the value begins at ambient temp (when cool) and climbs to 160 and stays there doing normal driving. I need to tow heavy and lock/unlock the TC to bump the temp much. Pushing 5 tons backwards up my driveway will do it for sure!
I can see how it would be easy to pick the wrong wire though. It's a 50 pin block and the labels cannot be read by mortal eyes without a lot of light. I pulled the connector to get a better look at mine before I tapped. On the right wire it should just be scaling voltage to temp... if there was a poor connection there could be voltage drop (but that would read low?). The only other issue could be calibration factor which could differ year to year. I don't know...
CTDCAL
Sep 27, 2003 03:22 PM
dansdad
Sep 6, 2003 09:00 PM
Sittenbull2
May 30, 2003 11:16 PM
Sittenbull2
May 15, 2003 04:15 AM
malibu
Feb 5, 2003 08:22 AM
