Amsoil ByPass
Old Apr 23, 2008 | 02:26 PM
  #46
AH64ID's Avatar
Because it would steal too much flow and psi from the motor.
Old Apr 23, 2008 | 07:01 PM
  #47
TonyB's Avatar
Originally Posted by high bid
...Is it to prevent full oil flow and prevent too much oil in the upper head?
Oil bypass systems do NOT need to be full flow; they are actually partial flow. If you were pumping full flow oil, you would have a significantly lesser amount of oil available for lubrication and cooling of internal components. IIRC, they like to use ~ 0.050" orifice to limit flow and keep oil pressure higher in the primary oil system.
Tony
Old Apr 23, 2008 | 07:49 PM
  #48
high bid's Avatar
ok, so I'd be ok w/a 2micron filter, 1/4 lines run from the primary filter thru the 2micron and then into the filter cap? I'm guessing the orifice goes pre-filter? Where can one obtain the orifice?
So caping the line going into the filler cap and drilling the smallest hole in it is out of the question? thanks for all the info!
Old Apr 23, 2008 | 08:08 PM
  #49
AH64ID's Avatar
The amsoil mount has the orafice in it... But I run the amsoil 2 mic absolute filter on the BK203 (BMK-11 mount) with 1/4" ID hydraulic hoses (locally made), so yeah, I think thats a good setup.
Old Apr 26, 2008 | 09:16 AM
  #50
high bid's Avatar
Thanks for all the info. Where have most of you connected the input hose for the bypass? I thought the 2nd gen factory filter housing had a port but it doesn't seem to.
With the price of oil these days, I can't believe more people wouldn't run a bypass setup much less the dealers install them from the factory.
Old Apr 27, 2008 | 09:15 AM
  #51
high bid's Avatar
What/where does one tap into the oil line for the bypass setup? thanks
Old Apr 27, 2008 | 02:14 PM
  #52
Ducman82's Avatar
there is a port on top of the stock oil filter houseing.. 1/8 NPT
Old Apr 27, 2008 | 08:58 PM
  #53
high bid's Avatar
gotcha! Ok, I was thinking that was something else. Thanks!
Old Jun 12, 2013 | 09:23 PM
  #54
Patriot_RAM's Avatar
Have any of you guys decided to start selling any of these driver side mount designs? I'd rather buy one than mess with trying to get one made at a machine shop. Most of the shops here refuse to work on anything automobile related due to liabilities, etc.
I've had the rest of the kit for over a year, just no way to mount it!
Jmac
Nov 10, 2004 07:41 AM
Lightman
May 3, 2004 08:53 PM
dodgediesel4x4
Dec 17, 2003 02:05 PM
RKCRWLR
Jun 27, 2003 09:01 AM
