All oil and fluid change
Old Apr 24, 2008 | 03:09 PM
SjLingenfelter's Avatar
Ok got 100k on the truck now so i wanna change ALL the fluids in the truck. Which fluids and oils should i run? What brand and weight and etc.....
Motor oil: Rotella
Trans fluid: ????
T-Case fluid: ????
Front and rear diff: ???
Thanks
Sean
Old Apr 24, 2008 | 05:27 PM
Roperteacher's Avatar
Motor oil that is 15/40 or 5/40 Ci4+ or Cj is fine
Trans will be the Syncromesh for the 04.
Transfer case is ATF+4
Front and rear diff is 75/90 GL5 rated synthetic. 140 weight if you tow heavy
Old Apr 24, 2008 | 06:11 PM
well the truck is a manf date of 03 but late 03 does it matter on the trans? its a NV5600.
Old Apr 24, 2008 | 06:41 PM
rich's Avatar
nope change it about every 6 months or 50k and it will last and your difs about every 50k
Old Apr 24, 2008 | 06:53 PM
no i mean the fluid for the trans
Old Apr 24, 2008 | 07:28 PM
If you have the NV5600 then Syncromesh is the one you want.
Old Apr 24, 2008 | 07:33 PM
where do i get it from and how many gallons
how much for the t case and diffs
Old Apr 24, 2008 | 07:39 PM
bradler's Avatar
I think a lot of guys with NV5600 also run Redline MTL.
Old Apr 24, 2008 | 07:54 PM
DiEseLjunKy's Avatar
don't forget 100K is time for a coolant flush too
Old Apr 24, 2008 | 07:56 PM
06RAM2500's Avatar
Owners manual has a page for capacities. T/C holds around 2.5 qts, rear diff. is about 4 qts., front diff is about 3 qts.
Old Apr 24, 2008 | 08:04 PM
I had to replace my waterpump at like 90k so thats good.
Old Apr 24, 2008 | 08:15 PM
dozer12216's Avatar
Consider changing PS fluid and brake fluid. Both are benefital services for life of components.
Old Apr 24, 2008 | 08:19 PM
Ya gonna change brake but how do you change PS
Old Apr 25, 2008 | 09:33 AM
2003Ram's Avatar
For the PS I use a big syringe with a hose and suck out the reservoir every 50k or so and replace with new fluid. That method gets most of it.
Old Apr 25, 2008 | 10:00 AM
Dieseljunkie's Avatar
I run Amsoil products through my entire truck, and I love them.
fatpete
Nov 11, 2010 05:55 AM
markm4
Jul 29, 2007 11:16 AM
RedRacer44
Jun 21, 2007 12:05 PM
schu
Jul 12, 2004 05:37 PM
doitl8r
Jun 4, 2004 11:14 AM
