Air Filter??? Normal?
Old Jan 19, 2004 | 11:07 AM
dansdad's Avatar
I just had my Diesel oil changed at 12000 mi. and notice the air filter was totally black. My new owners manual does'nt say how often to change it. Is this normal? Dave
Old Jan 19, 2004 | 01:28 PM
MikeyB's Avatar
Yes, it is normal. I recommend changing the air filter and fuel filter at 10k mile intervals.
MikeyB
Old Jan 19, 2004 | 07:31 PM
cp's Avatar
cp
What did the restriction indicator say? Eyeballing is a very poor way to tell whether a filter needs to be replaced.
The dirtiest air your engine will ever see is with a new air filter.
Old Jan 19, 2004 | 09:05 PM
dansdad's Avatar
what is a restriction indicator?
Old Jan 19, 2004 | 09:15 PM
Jeff in TD's Avatar
There's a little gizmo mounted on the air box. It has a spring loaded plunger that moves under vacuum, indicating how restricted the filter is, and when to replace it.
The plunger doesn't return until you push the reset button, so you can read it when the engine is not running... Just push the reset when you replace the air filter.
EverydayDiesel
22
Jun 3, 2010 12:10 AM
Wildhog
13
Aug 4, 2008 08:07 PM
herb
Jul 18, 2008 08:25 AM
nfsommer
Apr 16, 2007 09:21 PM
royta
Sep 17, 2005 10:25 PM
