air filter
Old Jun 22, 2005 | 06:10 PM
mitchkim's Avatar
air filter
how often should i change the air filter
the minder has not moved
its looks dirty on the bottom but i can still see light when i hold in up
i cant find a certian mileage limit in the manuel
it has 11,500 miles on it
Old Jun 22, 2005 | 06:29 PM
Hardwood's Avatar
I would replace it with a K and M filter you will hear the difference and performance will be much better.
Old Jun 22, 2005 | 06:42 PM
snow104's Avatar
First off look at your minder to see how much restriction there is.
That will tell you when to change it.
As far as replacement
Paper (stock filter does a good job of filtering)
If you want to upgrade for more flow
Many differant oppinions
Scotty uses foam with good results
AFE,K&N, and others may or may not flow better and may not filter as well as paper
Some require a complete air box to be installed.
Some drill holes oll over the stock air box.
Depends on what you want out of it, and how much $$$$$ you want to spend.
Good luck
Old Jun 22, 2005 | 09:31 PM
surfram's Avatar
How long should a stock type air filter last? I have been runnin the same napa gold for over 18,000 miles without the filter minder moving.
Old Jun 23, 2005 | 09:02 AM
jkitterman's Avatar
There is no way to judge how long the filter will last. Driving and enviroment conditions are the biggest contributors. I couldn't wait and had to take a peek at 22500 miles and about 2 years on mine and it looked bad but the guage says it was still flowing enough air so in it stays....
Old Jun 23, 2005 | 11:51 AM
rock's Avatar
I try to keep it simple. I change my oil every 7,500 so every other oil change I do the Difs along with the fuel and air filters. So I change mine every 15K whether is needs it or not. My filter minder hasn't ever moved, does it work?
Old Jun 23, 2005 | 11:56 AM
Jonesboro's Avatar
IMHO it's not as if it is a tough decision replacing the air filter early since the Fleetguard air filter costs only $15 at Cummins and it takes less than 5 minutes to do the switch.
EverydayDiesel
22
Jun 3, 2010 12:10 AM
Wildhog
13
Aug 4, 2008 08:07 PM
herb
Jul 18, 2008 08:25 AM
nfsommer
Apr 16, 2007 09:21 PM
royta
Sep 17, 2005 10:25 PM
