AIM rear drop shackels whos heard of them or even used them on our dodges?
Old Dec 22, 2007 | 12:46 AM
rip 112's Avatar
I think I'm gonna wait for the 4" front spindle lift, I haul too much to mess with the backend, besides maybe flipping the brackets.
Old Dec 22, 2007 | 01:44 PM
stock600's Avatar
Well they just arrived, they measure 3" on center from hole to hole. The stockers measure 4.5, dont seem like a lot 1.5" at the shackle itself will hopfully lower it that 1.5". But i believe thiers some geometry there that says it wont move it that full amoount. Or is that with just trying to lift it? Well see i think im going to wait tell tommorrow to install them. They look ok to me and well built if they just dont cause any fit issues!!! Ill let you know and ill measure before and after also. Later
Old Dec 22, 2007 | 02:04 PM
Allways_Lost's Avatar
So are they the longer ones?
Old Dec 22, 2007 | 02:12 PM
stock600's Avatar
No thier the short ones, thier only 3" center to center bolt hole. Even the package says 05 dodge 2wd 3500 Short style lowering shackles. I just hope i dont have the hard time CLeger67 did!
Old Dec 22, 2007 | 02:17 PM
On your truck does the leaf spring go on top of the shackle or under. I hope that makes sence to ya.
Old Dec 22, 2007 | 02:23 PM
stock600's Avatar
It makes perfect sense to me, it's the short ones like you said, my springs are under the shackle.
Old Dec 22, 2007 | 02:27 PM
http://www.v6f150.com/forums/showthr...+drop+shackles
This is how mine are set up. Leaf on top.
Old Dec 22, 2007 | 02:31 PM
Well it sounds like you got the right ones.
Old Dec 22, 2007 | 02:37 PM
stock600's Avatar
Ya looks good, i see no prob. with that. But ya mine is 100% oppisite of that mine are on the bottom, needing a shorter shackle, your set up needing a longer one to lower it. Thanks for the pictures! Pictures are worth a lot of words[and a lot of typing] ha ha for me Thanks Again. Now im really scarded i will run into the same issue as CLeger67!! I can feel it..................
Old Dec 22, 2007 | 02:38 PM
Cool hope it works out for ya. Let us know.
Old Dec 22, 2007 | 10:52 PM
hepjohn's Avatar
Yes, mine were the short one's. Stock shackles were 4.5" ctoc, aim were 3" ctoc. Mine and yours would take the shorter style to lower, later models and or mega cabs take longer one to lower. Did not even try to return given the return policy and the fact they got dinged up a bit. Can't remember the part number. Good luck with yours. Also, aim said these were supposed to only lower our trucks 1".
Old Dec 23, 2007 | 09:55 AM
stock600's Avatar
hepjohn, sorry if i repet any i dont have time to reread all post this morning, so you tryed to install them but was bad fit like CLeger67's correct? So bad you called it quits, whats your next step with them or lowering the rear? Where were going today for christmas i believe we will give er a shot. Shouldnt take long to see what im up against- What company did you order from if its the same and mine dont fit well give em hell. Ryan
Old Dec 23, 2007 | 04:49 PM
hepjohn's Avatar
As I recall I ordered them directly from aim. I had previously moved the spacer blocks from bottom to top of spring packlowering the rear about 1.25 inches. I'm thinking of living with that. Again, good luck and let us know how it goes.
Old Dec 24, 2007 | 12:16 AM
stock600's Avatar
Didnt get a chance to do it today, ive also fliped the 2 blocks from bottom to top, i gave around 1 1/8 drop on my truck, it better but want the other 2". Ill see what i gain from the shackles and prob. call it quits after that. Need to measure but im curious if i remove the heavy spring on the bottom if i can still reuse my factory u-bolts, this will yield another 3/4" also.
Old Dec 31, 2007 | 10:41 AM
hepjohn's Avatar
stock600. How did the shackles work out?
93-12Smoke
Mar 18, 2013 08:22 PM
M1Lover
Sep 24, 2009 09:41 PM
ddestruel
Mar 10, 2008 09:28 PM
13ALPHA
Jan 3, 2008 04:07 PM
12valve@heart
Sep 8, 2006 11:53 PM
