Aftermarket 3.42 gear ratio?
Old Dec 3, 2006 | 01:11 AM
dodgepower88's Avatar
I'm new to this and was wondering if anybody came across a 3.42 or 3.54 ratio for the 10.5 AAM. I would like to do this to lower my RPMs for highway speeds and I don't think that i would like 315 tires.
I think that i found some kits for my front axle, but I've been searching for the rear axle kit and have come up empty.
Old Dec 3, 2006 | 01:20 AM
Fiftygrit's Avatar
Diesel Power magazine had a couple of add`s in it for differant gear ratios, if you can get one of the books mays help.
Old Dec 3, 2006 | 06:40 AM
bulabula's Avatar
I wouldn't even bother going through the effort to change from 3.73 to 3.50'ish - you'll only drop 100 rpms or so. A hundred rpms among friends is negligible; you'll have to answer the question if its worth the cost of parts and labor? For two axles.
Old Dec 3, 2006 | 08:00 AM
bluepp's Avatar
I agree 100% with this . Were you buying a new truck and had a choise of the 4.10 it would cost you $285.00. But to swap, not worth it
Old Dec 3, 2006 | 09:56 AM
SSminnow's Avatar
It depends on how long he is going to keep the truck. And besides, that was not his question, his question was if someone knows of where he can find the gear set. The reason I say this is, I read so many posts on someone wants something, only to have people respond "it is not worth it" "I would not do it".....OK ,great, but that is not the question. If he would have asked, "Do you think it is worth swapping from a 3.73 to a 3.54?" Then your response is correct. BUT, he did not ask that.
I do not know where to locate a gear set, but scan Diesel Power for a vendor that may carry that gear, good luck.
Old Dec 3, 2006 | 10:29 AM
adkl1's Avatar
4.10's are only a $40 option. if dodge wanted higher gears in the trucks they would of put them in. these truck are ment to pull things not to get 25mpg.
Old Dec 3, 2006 | 11:13 AM
Thanks for the info.
I agree with your remarks on the cost thing and how it might not be worth it, but I am just trying to keep my options open if I want to do anything.
Old Dec 3, 2006 | 11:52 AM
Jfaulkner's Avatar
Muted User
Then I suppose all the older trucks (2002 and below) can't pull anything? They must not because alot of them have 3.55's! If you have enough power gearing is not an issue! Most people overlook the fact if you have a 6spd and you install 3.36 gears you can tow in 5th and use 6th empty for mileage, and an auto can drop gears on it's own.
I agree with you 100%. Answer the question then interject your opinion!
design
32
Jun 23, 2003 10:07 PM
mbw
Mar 5, 2003 05:38 AM
Garz
Feb 3, 2003 09:08 AM
Cutthroat
Jan 8, 2003 09:37 AM
accordionjohn
Oct 7, 2002 12:54 PM
