adjusting valves need help
Adjusting valve lash today on my 06, rotated clock wise to tdc, first time # 1 rocker arms tight. rotated again to tdc both loose,began check/adjustments as needed. rotate 360 clockwise began adjustments, got to # 4 exhaust it is tight and stays tight after backing off. i cant figure out whats up.
no it is 360*the following might help
Once you set the dampener to 12:00 and verify that #1 cyl rockers are loose then adjust the valves in this order.
Intake on cylinders 1-2-4 and exhaust on 1-3-5.
Spin the dampener 360# clockwise back to 12:00 then adjust,
Intake 3-5-6 and exhaust 2-4-6.
I believe the tolerance you want on the intakes are .010 and on the exhaust .026 on your 06. I set them so that I have friction on the feeler gauge. Reset torque on the jam nut to 18 ft#.
You can go in the firing order if you want too but there is no need for it.
The entire job takes around 1-1.5 hours, if its your first time it will be a little longer. Do yourself a favor and get feeler gauges with a 45* bend in them, it makes it a LOT easier.
Here is a link from Glacier's website with pictures/drawings:http://www.glacierdieselpower.com/im...Adjustment.pdf
And a extra tip, scribe your hood latch and take that thing off. your chest and stomach will thank you later.
Is there a reason you set yours to .020 for exhaust instead of .026?
On the earlier CR's the spec was .020 for exhaust but later changed to .026. Theory is the valve is closed slightly longer for better heat transfer from the valve to the valve seat.
MikeyB
MikeyB
mikeyB i think you are correct on this but i have heard that a component change of the valve seats was made for the 06 was the reason for the change. so far no one at cummins has been able to tell me witch is correct. we replaced all of our cams in the 06's with pdr cams and i set them to 0.020 not reolizing there was a change, i ran one of them about 30,000 miles before i found out about it. i reset them to 0.026 untill i find out if we ase correct. with the smarty jr , pdr cam, 50 hp nozzles and exhaust i am running 300* cooler than stock
no the lifters ase mechanical, we adjust our lifters about every 250,000 miles. we changed the camshafts out in our 06's to get rid of the in- cylinder egr, two had less than 2,000 miles on them when we did. this was in 06 and i was so use to using 0.020 that i never thought to check for a change
redramnc
Apr 18, 2006 06:16 AM
