Adding ATF+4 through shifter
Old Apr 16, 2010 | 09:14 PM
ironbridge's Avatar
I replaced the atf+4 in my manual tranny tonight. I used Castrol synthetic. I have been reading that if you tow a lot you need to add an extra quart through the shifter to keep the front bearing cool. How easily is that done? thanks
Old Apr 17, 2010 | 11:17 AM
DMH's Avatar
DMH
I looked at mine once, considering doing the same thing, but it looked like a real PITA to remove the cup holders and everything else associated with getting at the top of the transmission.
I would think it might just be easier to either jack up the drivers side of the truck, or even drive it up on run-up ramps to tip the tranny enough to add some extra.
I do have a question though. Why are you using a ATF+4 in your manual tranny? I just changed my fluid and I used Redline MTL in mine. This was the second change and I am real happy with the Redline MTL.
DMH
Old Apr 17, 2010 | 11:19 AM
Pooter's Avatar
DMH
Because thats what the G56s call for, ATF+4, heck they pretty much use it in everything now.
I need to do the qt overfill too, just havent wanted to open up the shifter yet. Getting the interior plastics out is cake, I just dont want to spill anything or make a mess inside since these seats stain if you look at them wrong.
Old Apr 17, 2010 | 01:15 PM
TedT's Avatar
You don't need to add an extra quart with the g56.
Old Apr 17, 2010 | 01:25 PM
ironbridge's Avatar
I'd rather not have to add the extra......I'd hate to spill on the interior. Thanks
Old Apr 17, 2010 | 01:42 PM
stock03's Avatar
It's very easy to remove the cup holders and shifter. I cleaned all the plastics when I removed it. Now it looks new again.
Old Apr 17, 2010 | 02:29 PM
D-Roc's Avatar
Good advice. I agree.
Old Apr 17, 2010 | 07:45 PM
Guardrail's Avatar
I just put my finger over the bottom of the fill hole and squirt it in. (It helps to put a hose on the end of the bottle tip) When you get enough in, throw the plug in and tighten it down.
Pig
23
Jun 4, 2010 01:01 PM
Mslaughter
Aug 24, 2006 06:44 PM
dieselfan
Aug 5, 2006 10:44 PM
NJDiverDan
May 19, 2006 05:03 PM
Pig
Mar 13, 2006 09:12 PM
