4x4 grinding 03
Old Aug 6, 2006 | 09:22 PM
sparky76266's Avatar
4x4 grinding 03
today i put in 4x4 hi &low made grinding nosie two wheel drive ok 68000 never changed fluildin front axle or trans everything has be working great
Old Aug 6, 2006 | 10:16 PM
Sittingbull2's Avatar
First off Help us out a little, Tell us about your truck (Fill in Signature of your truck and what it has own it.) This way we can help you, Lets see do you own a manual shift transfer or turn the **** type ? To go to Hi-4 just shift, let off the go pedal first. To go to Low-4 get rolling about 2 to 3 mph put transmission in neutral shift to low-4 then back to drive or 1st gear if it is a handshaker. someone else will chime in I'm sure that ought to work though.
Old Aug 7, 2006 | 06:15 PM
Wink
hope this will work
Old Aug 8, 2006 | 12:24 AM
bubba33's Avatar
Mine goes into 4 low while its not moving.
Old Aug 8, 2006 | 09:13 AM
dogger's Avatar
Transfer shifter type?
Originally Posted by sparky76266
hope this will work
Do you have a manual shift lever or an electronic shift switch on the dash for the transfer case?
L8r,..........dogger
Old Aug 9, 2006 | 10:04 PM
it is a stick on the floor.I took it to the dealer today lets hope for the best .NOW I noticed two cracks on the dash and i have a tear on driver side seat from the lumbar bracket at 68000 mi with 7/70 bumber to bumber should it be replaced ? The service manager said Iwould have call chrysler my self what do you think?
oneslowyfz
Dec 21, 2007 02:50 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
kwpatton
Jan 9, 2007 09:12 AM
cLAYH
Feb 6, 2004 10:59 AM
