48RE won't shift out of first
Old May 24, 2010 | 09:07 PM
trajan3's Avatar
My truck doesn't want to shift out of first gear. I was all set to replace the governor solenoid, and the pressure sensor after reading several posts in the forum. However, all of the TSB and member descriptions said it was at light acceleration. I give mine full throttle, light throttle whatever and it doesn't want to shift from 1st to 2nd. It doesn't hunt or shuttle back and forth. Speedometer works and when going down hill it shifted when speed got up to 30 mph. after that it shifted fine then came to a stop sign and it started again. I went to 3,000 rpms and I backed off accelerator and it shifted into second. 100,000 miles on trans. Any help would be appreciated. When I drove it home last night it was fine. Then this morning can't get it to shift. Fluid is oK.
Old May 24, 2010 | 09:29 PM
Tacomaman87's Avatar
replace the sensor and solenoid
Old May 24, 2010 | 10:28 PM
CLS LLC's Avatar
yep, second that. replace the sensor and solenoid. while your at it replace the filter and fluid too. i had the SAME problem with mine didn't matter what type of acceleration. you can get the parts way cheaper than the dealer at transparts.com
Old May 25, 2010 | 08:11 AM
hobbz's Avatar
hope you have more luck than me. when mine did that, i had to have a full rebuild...
Old Jun 6, 2010 | 12:24 PM
trajan3's Avatar
Thanks! problem solved
Thanks for the input. Replaced the governor solenoid and the pressure switch and truck runs great. Couldn't afford the upgraded solenoid so I purchased the "new" oem from ElectricalAdvantage.net Their prices are great and parts received were new and in the box. Shipping only took 2 day to get to me. They carry lots of transmission parts for a good price.
Old Aug 13, 2010 | 12:20 PM
frenchy21's Avatar
I have exact same 1-2 shifting issues.
Wondering if you tried manually shifting from 1-2 with gear shifter?
Mine will not shift manually, not sure if solenoid will fix that or if something else is wrong?
Old Aug 13, 2010 | 01:07 PM
berettaman's Avatar
frenchy,
When mine was doing that, it would not shift manually either. I replaced the sensor and solenoid and all was well again.
HTH
Dave
Old Aug 13, 2010 | 02:06 PM
illEatUrDuramax's Avatar
i had the same problem a month ago. ended up having to do a full rebuild too 2nd gear band just vanished. tranny guy said it was probably just the govenor solenoid, then i got the $2400 phone call
JohnT38
Mar 14, 2010 08:19 AM
Copper1272
Sep 21, 2009 11:58 AM
Cashless
Feb 22, 2009 05:47 PM
#2 only
Sep 7, 2008 07:42 PM
