48RE Service
Old May 20, 2006 | 10:39 AM
danram11's Avatar
48RE Service
Just got my truck back from the dealer, got the 48RE serviced. They changed the fluid and (2) filters in it. Is there actually 2 filters in our transmissions? I've only read about one. I know I should have done it myself but I have a trip to go on next week and didn't get a chance to change it. On the service order it says "Completed transmission service on 45RFE . Service writer advised me that it actually was a 48RE service that was performed. I'm a little leary of these "experts". Here's a list of the parts used. Does this look right?
Qty. FP Number Description
1 2464324-AC Gasket, OI 21004003
1 52118789 Filter, VA 21170001
2 5013457-AA Oil Autom 1081018
1 5013458-AA Fluid, Tra 1081018
Total parts cost $91.80
Old May 20, 2006 | 07:45 PM
HorseHauler's Avatar
Not sure on the 2 filters, thats the first I have heard of that. I have a case of ATF+4 that i got from the dealer and I just went out to get a part number off of it. it is:
5013457 AA
That matches this of what you wrote: 2 5013457-AA Oil Autom 1081018
But not sure what this means:1 5013458-AA Fluid, Tra 1081018 since it does say Fluid, Tra?
As long as they put in ATF+4 thats the biggest thing. I would go and show them those numbers and ask them to explain which each one means to make sure ATF+4 is in there...
Old May 20, 2006 | 07:48 PM
danram11's Avatar
Thanks Horsehauler, I've never heard of two filters either. Hopefully some others will chime in and clear things up..
Old May 20, 2006 | 07:57 PM
VikingDiesel's Avatar
how important is it from 1-10 to do your 48RE service at 30k miles?? Not really serivce, but TRANS FLUSH?? I got 34k and I still havnt done anything, fluid seems slightly darker than normal
Old May 20, 2006 | 08:29 PM
danram11's Avatar
I went to 40,000 , fluid had a slight brownish tint to it, but smelled fine. I didn't intend to go that long, but you know how that is. I'll do it every 30,000 in the future just to be safe.
Old May 20, 2006 | 08:51 PM
gerry's Avatar
I had the pan off mine when I put a deep pan on and I only saw 1 filtre in the pan area... That is not to say I missed one though.
Old May 20, 2006 | 09:40 PM
Lrdchaos's Avatar
Thought I read somewhere that the hemi transmisson was the trans with 2 filters.
Old May 20, 2006 | 11:22 PM
Spooler's Avatar
Yes, the 45RFE is the Hemi tranny. It does have 2 filters. One Pan filter and another can filter that filters fluid that comes back from the tranny cooler. The 48RE only has 1 filter. The pan filter. I flush my tranny every 30,000 and will change the filter at 60,000.
Old May 21, 2006 | 08:53 PM
moterhead's Avatar
What you've shown above is only one filter (52118729). Why do you say they changed two? The list shows two different part numbers for fluid/oil. I suspect one is quart size (as another verified) and the other is gallon size.The item listed as Gasket, OI is surely the pan gasket.
steelblitzkrieg
Oct 14, 2011 09:19 PM
dieselbeef
Jun 12, 2006 08:12 AM
stack_climber
15
Feb 21, 2005 01:49 PM
silverramer
15
Mar 12, 2004 08:04 AM
dublr
Feb 8, 2004 08:22 PM
