48re rebuild
Old Jul 14, 2009 | 04:42 PM
sgray04's Avatar
48re rebuild
I'm finally convinced that my TC won't unlock (shuddering and high revs at stops and a hard "clunk" if I go from N or P to D or R). I'm going to limp it to a shop tomorrow and was wondering if any of you could tell me if at 185K you think that the thing should be completely rebuilt or just repaired. My profile is not very complete, It's a 2004.5 2500 quad cab 4x4 with the auto, no mods and a daily driver.
Old Jul 14, 2009 | 04:49 PM
Fueled's Avatar
My first rebuild was at 149K, so i'd say go for it. Even if it's not a workhorse, I recommend you get a triple disc TC and some upgrades to the valve body, that way if you get hungry for more later on your tranny can take it.
Old Jul 14, 2009 | 04:55 PM
sgray04's Avatar
Thanks for the advice. I'm probably only keep it for another 1 or 2 years and never pull anything to speak of though. Any advice as to what the price of a stock or slight upgrade rebuild should be?
Old Jul 14, 2009 | 04:58 PM
Fueled's Avatar
I paid 3500$ at a shop here in Calgary, and I had problems 65k later. You would think a decent rebuild should last longer than stock. So make sure you discuss that. I think a good rebuild, with a triple disc TC and the proper upgrades without any corner cutting should run you about 4000$ Cdn. Also make sure they use the right fluid, this clown I went to used Dex 6 in ANY vehicle that came into his shop... yikes! ATF+4 Only for the 48re. Shop around, you can buy a HD tranny for 4-5 g's. That's what i'm doing next. No third rebuild. No way.
Old Jul 14, 2009 | 05:04 PM
sgray04's Avatar
Thanks Fueled, Right now I need all the advice I can get. would you go more than stock rebuild if you were going to get rid of it in a year or 2 and never pulled with it?
Old Jul 14, 2009 | 05:06 PM
Fueled's Avatar
Probably not... problem is the price difference might not even make it worth wile not to upgrade. Stock rebuild will still run you 3000$+. Plus you might change your mind and decide to keep it...
Old Jul 14, 2009 | 05:10 PM
sgray04's Avatar
Thanks again, sometimes the truth hurts but it is what it is, LOL
Old Jul 14, 2009 | 06:53 PM
dfranks's Avatar
Where did you get your rebuild in Calgary ( I want to make sure that I don't go there) PM me if you don't feel comfortable.
Old Jul 15, 2009 | 03:34 PM
Fueled's Avatar
Mister Transmission over by Chinook.
Old Jul 15, 2009 | 07:29 PM
dfranks's Avatar
Good to know, I have been going to National on 14 ST for a couple of years, ane he seems to get a lot of hotrods and diesels there.
Old Jul 15, 2009 | 08:20 PM
1985cucv's Avatar
you do not need a triple disc tc get a good single and you will be fine upgraded vb billet anchor strut and band upgraded servos and new clutches laminated flexplate.thats pretty much it. if you want a lot more power get a billet input shaft i will be doing my own in the future. oh and of course get a drain plug you can put in your pan makes changing fluid way better.
i run ams oil in mine.
Old Jul 16, 2009 | 12:14 AM
Fueled's Avatar
I heard that a good single will cut it, but i'm pulling a 14' dump trailer up to 10000 lbs all day every day, city stop and go. I still think a triple is better suited to that application, and even tho I have a drain plug on my tranny pan I drop the pan each time to change the filter. I run Mobil-1 ATF+4 and I change my fluid every 15000 kms. Small price to pay vs. a rebuild, and I don't have the know how, shop, or patience to even contemplate doing it myself. Billet shafts don't endure much strain from towing applications, when accelerating slowly and letting the torque do it's job. I usually crawl to about 40km/hr then get a heavier foot, depending on the load. But for mud bogging and racing when you need to throw down all the torque right quick, then ya billet shafts are key. For 1000$+ each I can't justify it for what I do.
Old Jul 19, 2009 | 11:50 AM
prochargeddart's Avatar
i like my drain plug, just because theres a whole lot less mess when you have to pull the pan.. convenience factor
csa
Apr 2, 2011 09:14 AM
pos dodge
Nov 9, 2007 08:39 PM
kprc51
Sep 30, 2007 01:02 PM
chsaverline
Mar 14, 2007 05:26 PM
