48RE pan drain plug
Old Jan 30, 2008 | 06:07 AM
dodg's Avatar
Question 48RE pan drain plug
I am changing the fluid in my '03 trans and have a drain plugt kit. I want to drill a hole in the pan to initially drain the fluid to avoid the mess. Where do you have your plug installed on the stock pan? I know the filter is in the center, just want an idea to drill a hole that will allow for the plug install afte tthe pan is off. Thanks.
Old Jan 30, 2008 | 06:39 AM
checkster's Avatar
i put mine on the pass side toward the rear of the truck. do a search, somebody had pics and everything where to put it to avoid some parts(cant remember what i was.
Old Jan 30, 2008 | 08:37 AM
04 Diesel's Avatar
That is where I put mine.
Old Jan 30, 2008 | 10:53 AM
HOV's Avatar
HOV
I have a spare pan if you want a backup in case something goes wrong. PM if you're interested.
Old Jan 30, 2008 | 05:54 PM
ANG012's Avatar
I have one in my pan. Just get a good drain plug and a nut to fit it. After you get the hole drilled put the nut on the inside of the pan and run the plug up through the nut from the botton and weld the nut all the way around in side the the pan. Remove the plug and put the seal on plug and the plug back in. If you use the jam nut it can come loose and leak. Just my way of doing it.
Old Jan 30, 2008 | 06:23 PM
ptgarcia's Avatar
I was going to do the same thing and said screw it and ordered a Mag-Hytec instead. I'm lazy like that.....
Old Jan 30, 2008 | 06:36 PM
Erik@LCD's Avatar
I have a pan all done with a plug in it if somebody needs one. Make me an offer (a case of beer would probably cut it)
Old Jan 30, 2008 | 06:42 PM
Dodgezilla's Avatar
Me too. I tried but can't seem to make it fit on my new truck.
Old Jan 30, 2008 | 06:45 PM
ptgarcia's Avatar
Dang, where were you knuckleheads when I asked about this last week?
SCCSURF
Jan 27, 2009 09:23 PM
Mechanos
19
Jan 31, 2006 10:08 PM
DMOBBERLEY
Jan 8, 2006 04:38 PM
03CTDCO
Jun 15, 2005 11:11 AM
Sonny
Apr 29, 2004 11:48 AM
