2500 vs 3500
Old Jan 11, 2007 | 09:38 AM
  #46
mule3010's Avatar
Originally Posted by TexasCTD
Exactly! What he said. ^^^^^^
All 3rd gen Cummins powered Rams (except some early 03 SO models with auto trannies) have the 11.5'' AAM rear axles.
Mechanically, the 3500SRW and 2500 trucks are the same.......except for the overload springs. Same Frame, Same Axles, Same Brakes, Same Wheels, Same Tires.
The GVWR of the 2500 is 9000lbs. The GVWR of the SRW 3500 is 9900lbs. The 3500 Dually is 12,200lbs. The GVWR is the rated (from chrysler) legal weight allowed of the truck and all of it's cargo.
The GCVWR is the same for all of the trucks. 21,000lbs with 3.73 gears and 23,000lbs for 4.10s. That is the weight of the truck, it's cargo, any trailer it is pulling and it's cargo. In theory, a 2500 truck will PULL just as much as a dually will (with the same axle ratio).........if you can load the trailer such that it doesn't overload the rear of the truck with pin weight.
The real weak point on both the 2500 and 3500 SRW is the tires and wheels. If you put on a set of Rickson 19.5'' wheels (or similar) with G Rated tires, there is not much you can't pull with these trucks. But you might still be over the GVWR of the truck or the GCVWR of the truck as DC rates them.
This is absolutley correct. I have the 2500 w/plow prep and the spring pn's are the same (I checked) I was going to buy the srw 3500, but for $200 less I could get the 2500 WITH the plow prep. They ARE the same truck minus 1 set of overloads in the rear. It is wierd there is so much confusion about this. I guess in a way it is DC's fault for confusing gas with diesel pn's.
Joe
Old Jan 11, 2007 | 01:39 PM
  #47
SOhappy's Avatar
Originally Posted by BigDave12768
59k
59K on the original ball joints is pretty good actually for these trucks. Mine only made it 35k.
Old Jan 11, 2007 | 01:47 PM
  #48
RustyJC's Avatar
Once you go over a 10k GVWR you need to have commercial insurance.
Not in Texas.
Rusty
Tree DR
Dec 1, 2008 07:14 PM
dragginlx
15
Mar 9, 2007 11:32 AM
ptgarcia
Sep 12, 2006 06:04 PM
Patrick Campbell
Mar 20, 2003 12:57 PM
Nov 1, 2002 03:48 PM
