2006 G56 clutch hydraulics upgrade
Here are some pictures of the new South Bend Clutch HYD-X-.750 replacement for the OEM clutch master/slave cylinder assembly.
OLD:
Side by Side:
NEW INSTALLATION:
Install was very easy. Waited until the sun went down, due to the heat index over 110 degrees. Just be careful when threading the slave from the engine bay down - the heat shielding on the new braided line to the slave cylinder and the battery terminal don't like each other for some reason.
The new SBC unit is adjustable at the pedal and comes prefilled/sealed. The only non unbolt/bolt up part of install is the new reservoir install.
The SBC unit comes with two self-tapping screws to mount to the firewall.
It was so easy a caveman (me) did it.
Improved the transmission/clutch feel and response 100%. It is better than new.
OLD:
Side by Side:
NEW INSTALLATION:
Down the road there might be an actual transmission upgrade.
So, it was not a waste of time.
Please note that the SBC reservior will only mount to one place without any fabrication of a bracket or interfering with other components for stock rigs.
Mine's got 35K now with a Smarty on low and 2000# on it's back the whole time. I'd do the OFE tomorrow if I had the buckeroos.
Itching for some modifications to everything, but not anything too expensive.
I have been running the Smarty Jr. on mine for over 20k miles now and no issues. I know others with a lot more miles and also no issues. I don't thing the dual mass has anything to do with it. There is no doubt the solid replacements are much better but the dual mass still hold up rather well.
A combination of weight and increased horsepower will cause the dual-mass to slip in 5th and 6th.
Just be sure the installer knows what he's doing. The dipstick that did mine closed up shop a month after my installation and he'd had to plug the trans in SIX times before he called South Bend to find out that a spacer had to be removed and discarded when the new flywheel goes on. I suspect he may have knocked a bearing slightly out of place and caused my noisy trans.
gadget the noise is normal the g56 design transmits engine noise more than any previous tranny. that was the reason they went to the dmf but they used a very poor design. the sb has a real pilot bearing also and will never give any trouble. all of our dmf's failed before 75,000 miles and one at 35,000 all had seep from the front seal. once you get to look at the dmf you will wonder how it made it that long. you need to run the g56 one quart over full to cool and lube the front bearing. if you wait to long to change out the dmf you will wallow out the front bearing housing. it is best if you change it before it go's out.
MegaTony06
0
Jul 22, 2011 01:06 PM
Sask
May 17, 2007 12:35 AM
Bart Timothy
Jul 20, 2005 01:36 AM
