Clutch hydraulics problem?
Old May 15, 2006 | 06:17 AM
GO 4LO's Avatar
Guys,
I need a little help diagnosing a clutch problem. A little background - I have a 2001.5 2500 4x4 with the NV5600 and an Iron Giant DD clutch. I went out on Friday to head to work, and the clutch pedal felt lighter than normal, I couldn't hear the floater plate rattling when I depressed the clutch, and she didn't want to go into gear. I assumed it must be the master or slave, and a guy at SBC had the same suspicion. I got SBC to overnight me the new pre-modified hydraulics setup they have and got the new setup installed over the weekend, but it's acting the same way (soft pedal, won't go into gear, no floater plate rattle). Assuming I must have gotten air into the system somehow, I tried what I've read in the archives here - keeping the slave lower than the master, holding it straight down, and slowly pushing the rod in and then using the clutch pedal to force fluid back down to the slave. I tried it fast, slow, wiggled it while doing it, etc. Everything I could think of. But I still have the same symptoms.
With the slave in my hand and someone pushing the clutch in, it only moves the slave rod about 1.5 inches - is that normal? Does it sound like I still somehow have air in the system, or have I misdiagnosed this? Thanks.
Chris
Old May 15, 2006 | 09:53 AM
Ph4tty's Avatar
I'm not much help, but remember to take the cap off the resovoir so the air has somewhere to get out. I think you're right that there's air in there- I went through the same thing last month.
Old May 17, 2006 | 12:50 PM
GO 4LO's Avatar
Thanks, Ph4tty,
I got another master/slave setup I'm going to drop in tonight. One quick question - you know the little split plastic collar that is on the male side of the connection between the master and slave? That stays on when I plug the two together, right? I assume so, and it seemed to go together okay last time when I did it that way - just wanted to double-check everything before doing this again. Thanks.
Chris
Old May 17, 2006 | 02:54 PM
halerazor's Avatar
my guess would be it's your pilot bearing or something to do with the clutch. usually if the hydraulics go out the clutch will not disengage
Old May 17, 2006 | 03:04 PM
PourinDiesel's Avatar
It might also be finger collapsed or spring broke in the pressure plate.
Or a build up of clutch material somewhere and its hanging the discs up.
Old May 17, 2006 | 07:57 PM
GO 4LO's Avatar
Thanks for the info, guys. I just tried the new master/slave, and that did not fix it either, so I guess it's internal. Time to pull the trans, I guess . I'll be sure to check what you guys mentioned - thanks for the help.
Chris
Nsomniac05
Dec 8, 2009 07:50 PM
timmiser
Jul 5, 2007 10:23 PM
6speedcowboy
Aug 25, 2006 07:51 AM
Neal Cassady
Nov 19, 2005 02:33 PM
Bart Timothy
Jul 20, 2005 01:36 AM
