2006 Coolant lost
Old May 4, 2010 | 11:13 AM
tonycamacho's Avatar
2006 Coolant lost
I'm not familiar with the 2006 models but I received call from a friend here in Mexico, he is losing coolant but can't find a leak. I experienced the same with my 1999 with the 53 series engine. I was lucky because Dodge installed a new motor under warranty. Was the 53 series engine also used in 2006 models? Has anyone on this blog with a 2006 ever experienced coolant lost problems. Looking for feed back so I can advice my friend.
Thanks Tony
Old May 4, 2010 | 11:16 AM
CoastalDav's Avatar
Have him check the small rubber hose behind the turbo that joins two pieces of pipe. It has a heat resistant covering, silver in color. The leak will show on the bottom of the transmission cover. The Anti Freeze in the 06 is red and when mine did it, it thought it was tranny fluid. Search on this site you'll find a picture of it.
Hope this helps.
Old May 4, 2010 | 09:11 PM
Z-MAN's Avatar
Thumbs up Coolant leak on 2006 RAM 2500 4X4
Hey Tony, CoastalDave is right. I recently hathe same problem and all I did was to tighten tha screw. It hasn't been leaking for 2 months now. I too believed it was tranny fluid, but it was actually coolant. Good luck.
Old May 5, 2010 | 10:08 AM
Thank you for the feedback I did relay this info and currently waiting for my friend to crawl under his truck to check the hoses. I also asked him to join us on DTR.
Old May 5, 2010 | 10:24 AM
CoastalDav's Avatar
Tony; This tread has a picture of the suspect over engineered hose.
Bottom of 1st page.
https://www.dieseltruckresource.com/...t=coolant+leak
Old May 5, 2010 | 01:54 PM
super10lbz's Avatar
I thought mine was the hose as well but ended up being the water pump housing would leak ever so slightly. Had to remove the air box to get a good look at it but under pressure i finally found it. Would drip towards the back of the compressor.
Old May 5, 2010 | 06:28 PM
NickBeek's Avatar
The other spot that it may be leaking is the small hose that goes from the radiator cap to the overflow bottle. The factory doesn't put a clamp on it and it will leak. Find a small spring loaded clamp that fits that hose and that will be cured.
Old May 5, 2010 | 06:52 PM
Fiftygrit's Avatar
Had both those with my 06, one other one is the screw in plugs just above the exhaust manifold, that seem to go into the head, one of mine was loose a bit and was weeping antifreeze, I tow a lot so she does warm up, anyways good luck
Old May 5, 2010 | 07:42 PM
wiskeyVI's Avatar
I've smelt anti frreeze from about the 1st year I've had mine, from time to time.
It has gone down in the overfell/resivoir bottle but not enough to add any.
I haver that same hose to replace, although there is no evidance of any leak anywhere.....
Old May 6, 2010 | 12:39 PM
Jeff in TD's Avatar
Yeah, it seems to be an 06 thing. Slight drip from the bottom of the bell housing.
Just snugging the clamps down cured it for me, but there is an updated hose with improved clamps.
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
Cummins600
May 8, 2005 09:53 PM
popeyesides
Dec 6, 2004 03:43 PM
