2003 no fuel in filter housing
Old Jan 23, 2011 | 04:26 PM
hfd376's Avatar
Drove truck home, about an hour trip, last night with no problems. It was cold, in the low teens, but nothing unusual.
This morning I had to jump start the truck, and it ran for less than a minute and then cut off. During troubleshooting I noticed that the bowl did not fill up, and it sounds like the lift pump is operating. It is very quiet tho. I have a P0088 code that returned after I disconnected the positive battery terminals.
Is there anything I can check before having it towed?
Doug
Old Jan 23, 2011 | 04:44 PM
BigIron70's Avatar
Cummins Guru
Sounds like a weak lift pump. If it is mounted on fuel filter housing then it's time to replace it. P0088 you could also have a stuck fuel control actuator. Fuel rail pressure above max limit. You need to monitor fuel rail pressure and see if pressure changes with RPM. If at max pressure engine will start hammering really loud and cause damage to fuel injectors or pressure limit valve do not drive with FCA code active.
Old Jan 23, 2011 | 09:55 PM
hfd376's Avatar
The lift pump either is not or cannot get fuel into the filter bowl, so its not running at all. I do not have the resources to monitor fuel pressure. I barely hear the lift pump running, but I don't think its pumping any fuel. Thanks for the reply.
Old Jan 23, 2011 | 10:11 PM
rockcrawler304's Avatar
I don't live were it gets cold enough to gel the fuel but could that be the problem? I imagine even if it is just starting to gel that it would not pump real well.
Old Jan 24, 2011 | 06:10 AM
hfd376's Avatar
Thats possible, I think its going to get into the mid 30s today, I'll try again after work.
Old Jan 24, 2011 | 06:46 AM
railroaderone's Avatar
get some fuel 911 at a heavy truck shop refill fuel filter and and see what hapens
BUFFALO_STEW
Dec 17, 2009 02:42 PM
dogfish
Jan 25, 2009 09:34 AM
Big Smoky
Mar 6, 2006 10:47 PM
royta
Sep 17, 2005 10:25 PM
Gumby
Jan 24, 2005 01:15 PM
