2" Spacer Removal on a 2006
Has anyone taken out the 2" spacers blocks from the bottom of the spring pack and moved them to the top to get your 5th wheel level? If so how much pin weight are you putting back on the truck? When you load your 5th wheel up does your truck sag a lot?
No I didn't take apart, all I did was take the U-bolts off and lift up the spring to clear the axle and beat on them. Stupid question I have.... Do I need to totally take the springs off the truck and put on the bench just to take the small blocks off? Thanx
If you look around in here you will find a thread with pics,very simple just move spacer to the top and put back together,only problem is when you remove rear brake caliper bolts wont come completely out of the caliper,still comes off though.
Thanks so much guys...I saw that link a while ago but I could not remember where I saw it.
Can someone tell me the torque values on the U-bolts and the bolts that go through the springs and spacers?
Thanks
Thanks
PEAKSTRYDE
Oct 11, 2007 04:20 PM
97on22s
34
Nov 3, 2006 10:41 AM
StealthRam
Jan 6, 2006 02:18 PM
Gotlift01
20
Sep 30, 2005 08:47 AM
