1st Diesel, short driving trips.
Old Jan 24, 2004 | 10:20 AM
CTDinMT's Avatar
I was worried about the short trips to, I only drive 15 min to work and when it was cold, temps would never rise above 140. Once I put on the Lund Cold-Front, by the time I am close to work the temps are usually close to 200 degrees. Much better peace of mind. You might want to try one or an equivelent.-Steve
Old Jan 24, 2004 | 10:50 AM
Jeff in TD's Avatar
I was looking at a fancy one by Alaska Tent and Awning
http://www.alaskatent.com/
But I decided it isn't really cold here very often or very long, so I just use cardboard. The local PD often sets out used targets for recycling, precut to the perfect size, already with some holes to let a little air in. Cut a couple holes on one edge, and you can hang it between the radiator and intercooler with zip ties onto the upper support...
Old Jan 24, 2004 | 10:56 AM
Dr. Evil's Avatar
Jeff, I dont know why youd want to install snaps on the front of your truck when there are so many other options
Old Jan 24, 2004 | 11:19 AM
Jeff in TD's Avatar
Quote: (Jeff, I dont know why your want to install snaps on the front of you truck when there are so many other options)
Dr Evil,
That's why I was looking at the Alaska Tent one, it installs under the hood.
I kind of like clean, factory look... but then tastes vary.
Jeff
Old Jan 24, 2004 | 02:17 PM
Dr. Evil's Avatar
Dr Evil,
Jeff
Sorry Jeff, my mistake....when I looked at the site it looked like their winter fronts snapped on the outside of the grill, like the Semi's run....
Old Jan 24, 2004 | 03:19 PM
Jeff in TD's Avatar
Dr. Evil,
I think they make both, and they seem heavy duty and high quality.
By the way, I was doing some reading on synthetic diesel oils on other threads... and found posts by you and Lightman particularly good reading.
I consider myself fairly well informed when it comes to motorcycles, and SH vs SJ, and so forth but am still getting up to speed on diesels. Anyhow, just wanted to say thanks for the good info.
Jeff
Old Jan 25, 2004 | 08:11 PM
magnumduckdog's Avatar
My mother works for UPS and drives a diesel. She starts and stops (and shuts the engine off) about 100 times a day. Even the gas engines are lasting 400,000 miles under these conditions and the diesels are going much further than that. You are wasting your energy worrying about wearing out the cummins engine. Almost all of my driving is less than 15 min trips and am not worried at all.
Old Jan 26, 2004 | 11:58 AM
cp's Avatar
cp
The big difference between the UPS truck and the original poster's is that the UPS truck gets warm. A warm start hurts nothing. UPS is using the diesel in the as it is intended to be used--start it up, then use it all day.
Cold starts are bad for engines--not warm ones.
MossyOakGlock
Nov 15, 2007 01:44 PM
scsulfri
Mar 30, 2007 08:22 PM
dhughe2
Feb 5, 2007 05:25 PM
LanceK
Apr 16, 2006 07:52 PM
Sohio
Apr 23, 2003 11:48 PM
