Exhaust Brake & Plugging In better for "short trips"?
Old Apr 14, 2006 | 07:51 PM
LanceK's Avatar
My commute to work is not very far and I'm concerned with the engine not getting up to temp long enough.
Would plugging it in for the winter AND using the exhaust brake for faster warmups help with this issue?
If so how much?
TIA
Old Apr 15, 2006 | 05:12 AM
TexasCTD's Avatar
I wouldn't worry to much about it. But having said that, You should take it out and let it stretch it's legs a couple times a week. You should put your foot through the firewall every once in a while and get the temps up.
I don't think a couple of days of cranks and not fully warming up will hurt it as long as you do get it to full operating temp every few days or so. My 2 cents.
Old Apr 15, 2006 | 01:34 PM
Jeff in TD's Avatar
I am in the same situation, in that I am only a couple minutes from work.
In the winter I do plug in below freezing, and if you have a Jake brake you may as well turn it on (once oil pressure has come up and stabalized) while you scrape windows.
Mostly, though, I also think it is important to get it fully warm at least once a week. Run it long enough to drive condensation/moisture out of the oil, and hard enough to burn off any carbon from the valves/injectors.
Old Apr 16, 2006 | 08:30 AM
LanceK's Avatar
Running it up to temp. 2-3 times a week won't be a problem.
I usually tow one day on the weekend. If not I'm running around for long enough for it to get hot.
Old Apr 16, 2006 | 04:21 PM
Jeff in TD's Avatar
Is the mega cab you have on order in your signature to be your first Cummins?
Old Apr 16, 2006 | 07:52 PM
12PACK's Avatar
I'd consider getting a winter front as well. You'll reach operating temp real fast, with the flaps closed, if there's a little highway time involved.
MossyOakGlock
Nov 15, 2007 01:44 PM
scsulfri
Mar 30, 2007 08:22 PM
dhughe2
Feb 5, 2007 05:25 PM
alltork
22
Jan 26, 2004 11:58 AM
Sohio
Apr 23, 2003 11:48 PM
