100K mi. and still on OEM brakes and rotors
Old Apr 23, 2009 | 11:25 AM
YFZ's Avatar
YFZ
at 55K miles I bought the original replacement front pads from Dodge and took them home to replace them. I took off the front tires and the thicknesses of the pads looked the same as the new ones. I checked the rears and they over 1/4" of pad left. I put the front pads back in the box and returned them to Dodge. I am now at 105K miles and wondering if its worth it to check on them. I can no longer take the tires off myself and retorque them; I would have to take it in for inspection.
Do the pads at all 4 corners last quite awhile or is this worth paying to check? I haven't turned the rotors yet. I don't have the shimmy/shake that is felt slowing down when rotors do need to be turned. anyone been down this road?
Old Apr 23, 2009 | 11:54 AM
FOXY005's Avatar
I am in the same boat you are, 105,000 miles on original brakes & rotors.
Had State Inspection done in March and pads & rotors are still fine.
Heck my original BFG tires still passed inspection with 105,000 miles,
I will be replacing the tires shortly though just for my own peace of mind.
Old Apr 23, 2009 | 12:01 PM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
just run the truck into discount tire and pay a couple bucks for a rotation. and while there off have a gander at your pads.
Old Apr 23, 2009 | 12:44 PM
cody459's Avatar
I got 95k miles out of my original pads and rotors and that was pulling a 40' g/n most of those miles.
Old Apr 23, 2009 | 12:59 PM
TexasCTD's Avatar
Discount tire rotates tires for free. I look at mine everytime I take my truck there. Im still on the OE pads and rotors too......with 108K now. They look like they will go to 200K.
Old Apr 23, 2009 | 01:29 PM
Blygy's Avatar
my 03 got the rotors and brakes done at 180,000 KM. I didn't believe they would run this long.. But i could hear the back brakes were steel on steel. Only one side though..LOL..
Old Apr 23, 2009 | 01:46 PM
Rednecktastic's Avatar
Dang 105K miles on the stock BFG tires! I really wish they made an E rated 35x12.50x17.
I one time got 89K miles out of a set of uniroyal tiger paws on an S10 that still had tread left.... Tread seperation is what got them.
Anyway I'm glad I read this because I was going to pull the wheels and check them now at 50K miles I won't worry about it.
Old Apr 23, 2009 | 03:10 PM
El Borrego's Avatar
I got about 100K on front tires and 125K on rears. Rotated them about every 30K. They were original BFG. Have been running Firestone and they seem to be doing good so far. Changed brake pads at 150K. Could have gone further but I don't like to screw up good rotors for the price of pads. About 35K of this was towing Fiver across a lot of mountains.
Old Apr 23, 2009 | 09:11 PM
jhenson's Avatar
I got well over 200K on my factory brakes but I also pulled a 53' trailer most of the time also. At 262K I am just now noticing that the rotors need to be turned.
Old Apr 24, 2009 | 12:21 AM
boostjunkie1's Avatar
The thing is with Manual Trannys and the Tow Haul Engine Braking of the 48re the brakes never really got a work-out on my trucks....... Being that brakes are allot cheaper to replace than clutches and auto trannys we should all start using the brakes more
Old Apr 26, 2009 | 06:30 PM
tmf1's Avatar
brake squeal
My 05's brakes squeal,I have had the dealer look at them and they say that there is plenty of pad left. However they can't tell me why they squeal anyone experience this?
Old Apr 26, 2009 | 07:16 PM
xtoyz17's Avatar
Caliper pins might need to be greased up.
Shawn
Old Apr 26, 2009 | 09:29 PM
rotax800's Avatar
115,000 km on my 06 and just had my front pad replaced and the rotors turned. Backs were still fine Factory tires lasted to 95,000 km.
SKATERHAULER
Oct 2, 2013 06:34 AM
Shaun Cockran
May 8, 2012 05:52 PM
04ctd
Aug 3, 2007 04:19 AM
BAJA MAN
Nov 21, 2006 05:49 PM
wildcargo
Nov 29, 2005 04:20 AM
