07 5.9 exhaust manifold leak
Old Feb 13, 2016 | 10:57 AM
Redtruck-VA's Avatar
I recently bought a high mileage 07 QC that needs a lot of help. I've put new tires on it, hubs, rotors and brakes. And this is where I ran into a problem. I have a exhaust leak on #6 between the head and manifold. I pulled it apart and found a concave area on the head's mating surface. The exhaust manifold looks ok. It had 4 stainless steel gaskets stacked together, I'm assuming this is original. The manifold bolts where tighten to god knows what. I had to use a breaker bar on all of them, but they were especially tight toward the rear #6. I know the real fix is to pull the head and have the ports surface. What are my alternatives if any for a temporary fix? Are there any gaskets that do better than others?
Thanks
07 Ram 2500 QC 5.9L 6spd 3:73 gear
Old Feb 13, 2016 | 12:38 PM
CRF450R RIDER's Avatar
when ever you do pull the head to get it fixed, make sure you get the maniflod resurfaced since it could be warped.
Old Feb 13, 2016 | 01:26 PM
Absolutely, Thanks....
Old Feb 13, 2016 | 01:43 PM
StealthDiesel's Avatar
This depends on how deep the concave well or gouge is on the head...
If its not too deep, you might try a thick, 1 piece aluminum soft gasket. Similar to used on headers for gas engines.
Something that's 1/8 to 1/4" thick.
Since the factory exhaust manifold is 1 piece, you will have to machine the flange on the #6 exhaust port on it to avoid stressing it when you tighten it down.
Stacking multiple factory gaskets will not work IMO.
Old Feb 13, 2016 | 01:49 PM
When I machine the exhaust port I intend to do the whole side.
Thanks,
Old Feb 13, 2016 | 01:52 PM
What I meant was to machine the #6 port on the exhaust manifold to account for a thicker gasket at that one port.
If you don't, the 1 piece ex manifold will be in stress when you tighten it down. This could cause cracking.
Old Feb 13, 2016 | 02:02 PM
Gotcha, yesterday I ended up using Felpro gaskets (a little thicker) and two of the SS gaskets in a combination on all the ports to keep it the same.
Old Feb 13, 2016 | 03:31 PM
Took the advice of using a thicker gasket and ordered a set MLS gaskets from Cometic. Cometic as far as I know makes the best gasket available.
Thanks,
Old Feb 14, 2016 | 10:37 AM
Like I mentioned, using multiple factory MLS gaskets on all the ports was not recommended.
The MLS gaskets are not really forgiving for surface imperfections but hopefully the Cometic MLS gaskets will work.
There is a ton of exhaust pressure and heat in there even on a stock Cummins.
Old Feb 14, 2016 | 11:47 AM
Do you have a link to Mr Gaskets THICK exhaust gaskets? I looked yesterday and came up empty.
Thanks..
lovemysan
Mar 13, 2011 12:36 PM
CLS LLC
Nov 28, 2010 09:57 PM
Txwelder
Dec 22, 2006 03:55 PM
jon96ctd
16
Sep 10, 2006 08:15 PM
Dusty Ratcliff
Apr 2, 2006 11:08 PM
