Oil/water Leak At Exhaust Manifold?
Old Dec 20, 2006 | 11:57 AM
Txwelder's Avatar
Popped the hood and noticed what looked to be some type of liquid leak on the #1,2,3, and 5 ports between the head and exhaust manifold, right at the gasket. Tried to scrape some off and smell it but it wont come off. I have not noticed this before and it concerns me. Any idea why this may be happening and what the cause is? Thanks.
Old Dec 20, 2006 | 12:49 PM
John Faughn's Avatar
The combination of those would led me to beleave that you have a fuel problem , unburned fuel going out the exhaust ,
My valve covers are a little damp in that area .
Leaks are one of those things that I really like to see .
Old Dec 20, 2006 | 02:11 PM
Txwelder's Avatar
Well unburned fuel bothers me. Wouldnt I see some moisture at some other point like around the turbo?
Old Dec 21, 2006 | 12:10 PM
The turbos intake , not as likey to show , you should look at any place that exhaust joints , look at the tail pipe and any joints on the in the system .
You should get the oil anlized , if you see anything that does indicate unburned fuel , becouse if you have fuel in the exhaust/unburned ,its also going to go down the cylinder walls .
Old Dec 22, 2006 | 11:28 AM
ccmckee's Avatar
I would suspect it's time for a new head gasket.These things are known to leak at the front and rear right corners with age.Mine started doing it last winter so i changed it this summer.
Old Dec 22, 2006 | 03:55 PM
Txwelder's Avatar
Well there is no fuel in the oil and no fuel in any exhaust area. Not sure what else to check.
CLS LLC
Nov 28, 2010 09:57 PM
co8tim
Feb 15, 2010 03:08 PM
kev211
14
Feb 22, 2007 03:39 PM
jon96ctd
16
Sep 10, 2006 08:15 PM
Gene Peterson
Jan 7, 2006 02:32 PM
