06 problems
Old Jan 3, 2014 | 10:50 AM
bulltamer's Avatar
06 problems
i have an 06 mega cab 4x4 auto, running rough so everyone told me it was injectors , so i dropped 3k on reman units. thought it fixed the problem until the engine warmed up to operating temp. changed injector wiring harness/gasket still doin the thing. omhed them out and came up with .50 ohm on the injectors. also replaced the whole engine wiriing harness still doin the same stuff warm up and run rough misfire, getting codes 2149, 0251, 0606, 0088. bout to go insane with this truck
Old Jan 3, 2014 | 12:24 PM
AH64ID's Avatar
Have you checked rail pressure?
0606 is a ECM hardware issue. Have you cleared the codes?
Old Jan 3, 2014 | 02:03 PM
bulltamer's Avatar
yea rail pressure checked out and Lift pump pressure checks out to and yea the codes are cleared they come back when the truck hits operating temps
Old Jan 3, 2014 | 02:41 PM
AH64ID's Avatar
Then I think you might be looking at a new ECM, which sucks.
Old Jan 3, 2014 | 03:50 PM
JP-4.5's Avatar
Make sure the rail pressure sensor is not plugged in backwards. Is very easy to do.. Don't ask me how I know.
meaning the connector from harness onto the sensor being backwards.
Old Jan 3, 2014 | 07:16 PM
RD TRCTR's Avatar
Been there, done that, it sucks! With the issues you are having I would check that connection as well.
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
