06 2500 fuel leak
Old Oct 27, 2011 | 03:43 PM
chiefculprit's Avatar
06 2500 fuel leak
Driving and saw smoke at signal. Pulled over smelled fuel, opened hood and found the the metal line on injector #5 (from the front end) from the rail to the injector was spraying fuel. The leak is on the metal tube right after it comes out of the bolt at the injector. Also noticed the clamp that holds the line was loose, would that cause the failure? Is the a common failure?
Old Oct 27, 2011 | 06:21 PM
PWong's Avatar
Yes and Yes.
Replace the injector line and check/tight all the other clamps and holding brackets for all the injector lines.
npmsu777
Dec 3, 2014 07:43 PM
Jaybug
Dec 24, 2013 11:23 PM
sluketic
Oct 7, 2010 11:55 PM
dieselfuelonly
Jun 22, 2009 06:13 PM
donhov
26
Jan 6, 2006 07:29 PM
