98 2500 Fuel leak
Old Dec 2, 2014 | 02:58 PM
npmsu777's Avatar
Exclamation 98 2500 Fuel leak
Started leaking fuel from the filter assembly/housing. Clearly it's leaking from the fuel heater plug at the top. Is it most likely a faulty O-ring/seal causing the leak or that the heater plug, filter housing is cracked and needs replacement.
I don't see any damage from the outside. Wanted some ideas before taking it apart.
Old Dec 2, 2014 | 06:50 PM
patdaly's Avatar
Hopefully housing is fine, o-ring is a known problem.
Here is all the info you should need, not a bad job at all.
http://forum.mopar1973man.com/index....y-fuel-filter/
Old Dec 3, 2014 | 12:29 PM
VADSLRAM's Avatar
definitely the Oring.
Fairly simple to fix. Take off the whole unit and you can get it on a bench to work. Clip off the plug and you can pull the whole heater unit out of the housing. I have a HF set of nitrile orings I bought and found one that fit. Screw it back in place and crimp on a new plug..no more leaks.
Old Dec 3, 2014 | 07:43 PM
DIESELWRKS's Avatar
good to hear.
now why cant all fixes go that smooth.
Jaybug
Dec 24, 2013 11:23 PM
chiefculprit
Oct 27, 2011 06:21 PM
sluketic
Oct 7, 2010 11:55 PM
dieselfuelonly
Jun 22, 2009 06:13 PM
donhov
26
Jan 6, 2006 07:29 PM
