Tranny leak from bellhousing?
Old Oct 26, 2011 | 08:02 PM
silverbullet02's Avatar
Truck just started leaking a little tranny fluid from the bellhousing. Not a lot, just a little bit. Is this a common problem? I haven't pulled the inspection cover off to look, but if it is a common problem is it a seal on the front of the tranny or coming from the converter seal? Should I be concerned? I'm leaving in a few days to drive from WA to TN to OH and back to TN. I'll be loaded heavy with camper and car trailer. Hopefully it's not a big deal. Thanks for any input,
Brian
Old Oct 26, 2011 | 08:34 PM
Rpainter's Avatar
sounds like the trans is a little overfull and you got the fluid hot. It probably is coming out the vent behind the comverter and leaking out the inspection plate.
Old Oct 26, 2011 | 09:43 PM
rockcrawler304's Avatar
Make sure it's not coolant. There is a small hose up top towards the back on the passenger side about 4 inches long. Check those clamps. This leak was very common on the 06's (mine did it) but not sure about the 07's. It runs down to the bellhousing and then drips under the tranny and makes you think it is tranny fluid.
Old Oct 27, 2011 | 08:36 AM
no_6_oh_no's Avatar
Ditto on checking to make sure it is not coolant from the infamous hose under the turbo.
Old Oct 27, 2011 | 04:14 PM
Yep, it's coolant. I just drove it to see if I can make it do it again. In the picture, is this the culprit? Also, what antifreeze do these things take? My bottle is a little low. I noticed I had a little antifreeze leak last year, but never found it and it stopped. Just started the other day after a long drive and it was about 10-15 degrees colder that night than it's been all year. Thanks so much for the help!
Brian
Old Oct 27, 2011 | 06:16 PM
PWong's Avatar
Mopar Antifreeze HOAT or Zerex G-05.
Old Oct 28, 2011 | 08:45 AM
That is the hose!! Glad it was not the tranny leaking
Common
Jun 9, 2008 12:16 PM
glennh220
Jan 19, 2005 09:36 AM
moparguy
Nov 1, 2004 04:08 PM
Palmetto_kid
26
Apr 16, 2004 09:02 AM
Commatoze
Mar 17, 2004 08:35 PM
