What's that little hatch on the bottom of the bellhousing?..
Old Mar 4, 2004 | 09:25 AM
Commatoze's Avatar
While changing the oil last Sunday, I noticed a little "wetness" around that little hatch on the bottom of the bellhousing. It's attached by small bolts. What's that hatch for? The wetness appears to be crankcase oil.
Old Mar 4, 2004 | 12:52 PM
billg's Avatar
That is a torque converter inspection plate. Remove it to inspect your TC. On your DTT TC there will be a drain plug, if you ever want to change all the fluid you can drain that to. If the fluid is oil you could have a rear seal leaking. I would pull it and take a look.
Old Mar 4, 2004 | 01:39 PM
Commatoze's Avatar
Thanks Bill. I'll pull it as soon as I get a decent day. If it is the rear seal, I need to get it before the truck is out of 7/100K warranty. No drips yet, just wet. Thanks!
Old Mar 4, 2004 | 03:18 PM
Commatoze's Avatar
BBD, you mean there's oil pan bolts up there besides the torque converter?
Old Mar 17, 2004 | 07:52 PM
fschiola's Avatar
OK I'm a little confused. Isn't a DTT an aftermarket transmission? If so, why would DC warrant the rear seal on the engine if it's been "modified"?
Old Mar 17, 2004 | 08:35 PM
Commatoze's Avatar
I have a DTT exhaust.....
sootnsmoke
Oct 14, 2012 07:00 PM
tauberson
Oct 10, 2008 04:11 PM
Puke
May 10, 2007 07:12 PM
