What's that little thing at the bottom of the radiator?
Old May 10, 2007 | 03:09 PM
Puke's Avatar
Two times now, I have shut my truck off...and had some anti-freeze puddle up under the drivers side.
I looked and looked and couldn't find anywhere I thought it was leaking.
Then I pulled of the windshield squiter tank...and think I may have found it.
There is a little thing...near the bottom, on the inside (motor side, drivers side also) that I could turn a quarter of a turn and then back again...but nothing came out????? I am thinking this is some sort of drain valve built in to the radiator..and it may be kind of plugged up (since nothing came out when I turned it a quarter turn).
Anway, I turned it back where it was, put the thingl back together..and it didn't do it again for a few days...then all of a sudden,...a puddle of antifreeze on the ground again.
Has this happenned to any of you...I cannot figure out what it is.
Old May 10, 2007 | 03:12 PM
Mcmopar's Avatar
It's called a petcock and you use it to drain the radiator. On our trucks turn it counter clockwise a 1/4 turn and "gentle" pull it out.
Old May 10, 2007 | 06:16 PM
Puke's Avatar
You mean that thing comes completely out?????
Do you think if I pull it out....
Then clean everything well,
Then put it back again...
My problem will be fixed????
Or am I going to be stuck buying a new radiator at some point.??
Old May 10, 2007 | 07:12 PM
Tate's Avatar
You won't pull it all the way out. 1/4 turn, pull, and then another 1/4, and it'll start draining.
HelenaTDI
Mar 28, 2009 09:56 PM
1985cucv
Jul 18, 2008 07:29 AM
BearKiller
Jan 29, 2006 09:28 PM
Stillman
Mar 21, 2004 04:52 PM
