05 6 speed high idle working
I got a cummins computer wire yesterday. # 3164263 12.00 + tax installed in pin #22 works just fine. also have cummins clutch switch but don't have any instructions on where to attach the 2 wires .I think one should go to ground and the other to pin #22. has any one done one of these yet.? switch cummins #3871395 $40.00 thanks Wayne
remove plug B on the PCM (the one toward the rear of engine) you have to disconnect the whole plug from the PCM, (there is a 4mm allen screw in the center) push the sealing plug out of #22, I used a paper clip (starting at to left,count across, there are 50 pins total, #22 is second in from left, third row down) the cummings wire#3164263 then must be grounded then it must be enabled by dealer or with dullydog downloader
Spooler
21
Dec 26, 2007 09:38 PM
jmccart
Jun 12, 2007 02:12 PM
robert78.5
Feb 17, 2007 01:16 PM
fade94
Feb 16, 2007 10:15 PM
