03 engine and trans....
Old Dec 4, 2005 | 06:17 PM
ataboy9026's Avatar
Anyone know how to find out what engine block a truck has?(I hear the 53 is something to stay away from) And also does anyone have a Gorend tripple disc converter in their 03 up truck? I put one in my 95 and it was a completely different truck to drive. I wondered if they were as good for the 03.I also wanted to get the Nitto Terrea Grapper All Terrain tires size 295/70/17 for my stock rims and lift. Does this work okay or would a leveling kit be something I should do before the tires? Does anyone have these tires? how do they wear? fuel mileage? And how to reset speedo for new tire size?
Old Dec 5, 2005 | 11:21 AM
bulabula's Avatar
You should do a search on this site for that info. I believe someone's even got pics to ensure you're looking at the right stuff.
You can also search for updating ECM with new tire information (rev's/mile).
Old Dec 5, 2005 | 07:34 PM
Lightman's Avatar
In 03 there were SO's and HO's.. As far as I know both are excellent. There is a label on the side of the valve cover that tells the hp/engine info. It may also be in the glove box, not sure.
As far as the trans and tire questions, spend some time searching and reading on this forum. There are several running that brand and other brands of aftermarket trans parts.
The dealer can reprogram the ecm to correct the speedo for larger tires. You have them reset the pinion factor to the proper rpm for your size tire. That number is listed on the website typically of the tire manufacturer, and the dealer will likely charge you a half hour labor. Good luck!
Old Dec 5, 2005 | 09:50 PM
J BODY's Avatar
that would be the ABS module.
Old Dec 5, 2005 | 09:53 PM
drew03's Avatar
they called it the pinion factor when i had mine done.
Old Dec 5, 2005 | 10:09 PM
J BODY's Avatar
which is adjusted in the abs module.....
Old Dec 5, 2005 | 10:25 PM
Lightman's Avatar
Watch him as he backpeddles folks!
Old Dec 6, 2005 | 02:43 AM
Hounddog's Avatar
The "53" block ended in the 2nd generations.The 2nd generation forum can tell you what year models.But NO 3rds have ever been mentioned.
Old Dec 9, 2005 | 07:42 PM
JWalker's Avatar
03 engine
Check the vin. 8th digit from the left. 5.9L is 6 and the 5.9L HO is C.
EverydayDiesel
19
Aug 2, 2007 05:36 PM
squirrel
Mar 31, 2007 09:24 AM
Commatoze
Oct 29, 2004 03:42 PM
live wire
Jul 21, 2003 07:26 AM
