Cleaning Up Engine And Trans? - Engine Degreaser
Old Jul 30, 2007 | 07:09 PM
EverydayDiesel's Avatar
Im curious how yall are cleaning up all the grime and sludge underneath the hood and trans area? Are you using any chemicals?
Old Jul 30, 2007 | 08:01 PM
Staton's Avatar
Purple Power in a spray bottle, let it sit...hit it with a pressure washer from a distance. And stay away from any powerful sprays in the direction of the intercooler, radiator, tranny cooler fins.
After that; relocate the crankcase vent and you should be clean for a while.
SC
Old Jul 30, 2007 | 08:49 PM
joeairforce's Avatar
i used ENGINE BRIGHT from auto zone
Old Jul 30, 2007 | 09:23 PM
300sd2500's Avatar
I like the GUNK gel it clings alot better so it stays on longer, it also smells like oranges. Then the pressure washer.
My brother swears by a engine degreaser called STEAM.
Old Jul 30, 2007 | 09:44 PM
wrangler04's Avatar
Dosent get any better than brake cleaner. Just dont spray your plastic stuff.
Old Jul 31, 2007 | 03:26 AM
dodge2005's Avatar
I have used Simple Green in a spray bottle, spray it on let it sit and power wash away. I also use it on th grill and mirror when the bugs are really bad.
Old Jul 31, 2007 | 05:23 AM
i just go to a quarter wash to spray mine...since they will have an oil water seperator........and i don't wanna mess up my driveway with oil....
Old Jul 31, 2007 | 12:54 PM
RowJ's Avatar
I've had great luck with Simple Green also!
No one mentioned so....don't forget to cover alternator with a plastic bag first!
RJ
Old Jul 31, 2007 | 04:38 PM
gmctd's Avatar
The autozone stuff in the tall orange/white can - flushes white so nay-bors don't get upset - use the lower tap on your house water heater for a heated-water flush, really gets the grime off, dries quickly - max temp of about 140deg at that lower tap, so is safe for most garden hoses - dunno about cheap lawn hoses, tho - also is good flush for the sediment, calcium, lime, rust in the botton of the hot water tank
Don't even wash the engine when it's at operating temperature - that heavy mass may react to sudden surface cool-down with warps and cracks, and you'll be sorry...............
Old Aug 1, 2007 | 05:35 PM
pappyscrapster's Avatar
SC
Have a question about relocateing that vent, where and how? If I start trying to do it I'll end up adding 22feet to it and running it to all the grease fittings hahah any help would be keeping me outta trouble,,
Thanks
Old Aug 1, 2007 | 05:40 PM
I took about 7 ft of hose and extended it just past the wheel.
I did away with the can. Im not sure if it needs that can but with 7 ft of hose it shouldnt make that big of a difference.
Old Aug 1, 2007 | 06:32 PM
wcbcruzer's Avatar
I'm kinda iffy about using a pressure washer on the engine. I'm looking for someone with a steam cleaner.
That's gotta be expensive...
Old Aug 1, 2007 | 06:53 PM
Hahah Im lost ,,,
Ok I give I thought the vent was that rubber tube that hangs down (drivers side, front) and gets hot oil drippings on everything the wind decides to deposit it on,, "Yikes" what is this can your refering to?
Old Aug 1, 2007 | 08:27 PM
wrangler04's Avatar
I pretty much get it for free from work.
Old Aug 1, 2007 | 09:04 PM
don't know if the '99s had it but the '01s have a "can" on the end of the vent tube to catch any oil drippings.
